RAM not running at 3600MHz on AsRock B450 Steel Legend
Hi there, so recently I bought a new gaming pc and bought a ASRock B450 Steel Legend motherboard and 3600MHz 16GB Aorus RAM, the Motherboard just refuses to run the memory at 3600MHz it just reboots till stock speeds are set. Pls help me I think I have a faulty motherboard
1 minute ago, curiousmind34 said:
What happens when you set it to 3200mhz?
Rn I’m running it at that speed (3133 to be exact) it just doesn’t go further. The motherboard says it can handle 3533 just fine. Recently my friend too built (paid some one to build it) a pc and had the same problems, he is running at stock speeds 2666
You might not be able to hit 3600 mhz. Neither is on the QVL of the other.
https://download.gigabyte.com/FileList/QVL/memory_AORUS-3600-16GB_200709.pdf
https://www.asrock.com/mb/amd/b450 steel legend/index.asp#MemoryPR
Project Hot Box
Oppbevaring
Why is the 5800x so hot?
With what CPU?
Desktop benching:
What CPU do you have? The only issue I've had with my own B450 Steel Legend was getting my memory to run at 3000MHz. It took a few attempts, but I was able to get it working and it's been rock solid since then.
Phobos: AMD Ryzen 7 2700, 16GB 3000MHz DDR4, ASRock B450 Steel Legend, 8GB Nvidia GeForce RTX 2070, 2GB Nvidia GeForce GT 1030, 1TB Samsung SSD 980, 450W Corsair CXM, Corsair Carbide 175R, Windows 10 Pro
Polaris: Intel Xeon E5-2697 v2, 32GB 1600MHz DDR3, ASRock X79 Extreme6, 12GB Nvidia GeForce RTX 3080, 6GB Nvidia GeForce GTX 1660 Ti, 1TB Crucial MX500, 750W Corsair RM750, Antec SX635, Windows 10 Pro
Pluto: Intel Core i7-2600, 32GB 1600MHz DDR3, ASUS P8Z68-V, 4GB XFX AMD Radeon RX 570, 8GB ASUS AMD Radeon RX 570, 1TB Samsung 860 EVO, 3TB Seagate BarraCuda, 750W EVGA BQ, Fractal Design Focus G, Windows 10 Pro for Workstations
York (NAS): Intel Core i5-2400, 16GB 1600MHz DDR3, HP Compaq OEM, 240GB Kingston V300 (boot), 3x2TB Seagate BarraCuda, 320W HP PSU, HP Compaq 6200 Pro, TrueNAS CORE (12.0)
AMD Ryzen 3600
1 hour ago, NathanGTR112 said:
AMD Ryzen 3600
Lastest BIOS and chipset drivers?
Desktop benching:
Yep!
58 minutes ago, NathanGTR112 said:
Yep!
DOCP or XMP enabled right? Otherwse it will be 1.2V with trash timings.
Desktop benching:
Yea its XMP and AsRock just replied to my request email and solved my problem. Apperantly the problem was of the CS, tcl, trcdwr, etc. Thanks for helping tho
  • 1 year later...
Could you share what did you change (values) to get it working? I'm facing the same problem.
  • 2 weeks later...
