Help with self hosting email on a Rpi 0.
38 minutes ago, OrangeSunshine said:my own email server
You will need: Postfix, Dovecot and MariaDB / MySQL (optional SpamAssassin).
You will also need a static IP, domain name, some DNS records and SSL certificate (unless you want your mail to end up in other peoples spam folder).
Linode has some nice tutorials about stuff like this, I suggest you start there:
https://www.linode.com/docs/guides/email-with-postfix-dovecot-and-mysql/
Once you've set it all up , head to: https://www.mail-tester.com/ to see if it is working and what things you should improve in order for your emails not to end up in other peoples spam.
A word of warning, if you are experienced Linux user setting all this up will take an hour or two, if you aren't... well it will take a while.
PS I've set up several mail servers over the years for business use, I would never setup one for personal use. IMHO just isn't worth the effort. Beside the setup you gotta keep in mind that you will have to take care of backups, redundancy, server ( in your case Pi ) availability etc.
