HELP PLEASE 1st ever build
Solved by Fasauceome,
1 minute ago, Max L said:how many fans will one argb header be able to handle a argb spliter?
5 or 6 fans can easily be run off one header, at least. The fans appear to have a standard 3 pin daisy-chain design to them, should work just fine.
Nebcs ·
FancyPants101 ·
l3eyond ·
1
