some big and silent fan?
12345678
right now I'm using an home fan to cool my pc, but it's noisy
anything big (35cm) and silent?
and also that's cost effective on my electrical bill even though they shouldn't use that much power
I'm using it cool my gpus
so if your mining imo moding the gpu cooler and adding a pc fan to it would be better and you can preserve the gpu fan when you go an sell it. be quieter, cooler.
but it would depend on your gpu and how complicated the heat sink is. i added 120mm fan to rx 470 but the original fans were broken because of mining but the heat sink was easy to take apart.
Edited by thrasher_565
Corsair Lian Li Bykski Barrow thermaltake nzxt aquacomputer 5v argb pin out guide + argb info
5v device to 12v mb header
Odds and Sods Argb Rgb Links
-> Moved to Cooling
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
2 hours ago, LogicalDrm said:
-> Moved to Cooling
gosh I missed all sections, I'm sorry 😅
