The only good wireless headset I can think of is the Logitech G930 but those are $100.
I know there are a couple of cheaper ones like the Plantonics ones and the Logitech H600 but I don't know if those are that great.
CPU:Ryzen 9800X3D GPU: RTX 5080 MB: Asus ROG X870E  RAM: G.Skill Trident Neo 64gb CPU Cooler: ROG Ryujin III
https://linustechtips.com/topic/132586-good-wireless-headphones/#findComment-1764685
At that price, you are really short of options. The best I could recommend is a wireless headset for Skype chats. Failing that, the only one I can suggest bothering with is the Sennheiser RS 120, which is almost certainly out of your budget.
Want to find parts in your budget? Logical Increments is the guide you need. | In the market for a headset? Read this thread. | If you're looking for headphones, please refer to this thread. | Stop being backhanded when offering advice.
CPU: Intel i7-3770K @ 3.5 GHz | CPU Cooler: Thermaltake Frio OCK | Motherboard: ASUS P8Z77-V LK | Memory: 16 GB Corsair Vengeance LP (DDR3-1600) | GPU: MSI Radeon HD 7870 GHz Edition x 2 (Crossfire) | Storage: 120 GB Kingston SSDNow V300 SSD, 2 TB Toshiba HDD | PSU: Corsair TX850 V2 | Case: In-Win Mana 136 (Black)
Monitor: ASUS VS248H-P | Keyboard: Corsair Vengeance K70 (Cherry MX Brown) | Mouse: Logitech G500 | Speakers: Logitech X-140 | Headphones: Philips Fidelio X1, Sony MDR-X05 | Webcam: Logitech C510
https://linustechtips.com/topic/132586-good-wireless-headphones/#findComment-1764686
[AMD Athlon 64 Mobile 4000+ Socket 754 | Gigabyte GA-K8NS Pro nForce3 | OCZ 2GB DDR PC3200 | Sapphire HD 3850 512MB AGP | 850 Evo | Seasonic 430W | Win XP/10]
https://linustechtips.com/topic/132586-good-wireless-headphones/#findComment-1764715
You want legitimized explanations and good input. Not going to waste me time if you don't. You feel?
Ya I want explanations, Can I have some now? "Not going to waste me time if you don't" I don't understand!?
"Believe in yourself. Cuz that's the way to start."
https://linustechtips.com/topic/132586-good-wireless-headphones/#findComment-1764884
My*, still human, still make mistakes.
Wireless, compresses an audio signal in order to fit the "full signal" into a smaller bandwidth, that just part one.
Because you can not power a headphone over wireless, and wireless is digital, you have to fit the dac and amplifier into the headphone, generally resulting in a poor quality amp....Secondly, you make mostly for the feature and less for the quality of product.
Headsets are kinda sub par, or over priced, and generally both.
https://linustechtips.com/topic/132586-good-wireless-headphones/#findComment-1765151
