Corsair SF600 or Fractal Design 650W Ion SFX-L for Mini ITX
3 minutes ago, DaveCad919 said:Do you think it’s more worth going with the Fractal SFX-L?
It's a rebrand of the Seasonic SGX 650W. It's a decent PSU and 108 Euro sounds about right for it.
Since you're interesting in noise both the Fractal and Corsair units have semi-passive fan modes where the fan won't spin at low loads/temps.
2 hours ago, DaveCad919 said:Corsair 600W SF600 SFX-PSU, 80 PLUS Gold (7 year warranty, brand new 134€) The corsair one I could buy used for 80€ -> warranty until 2026
If it has warranty until 2026 then it was manufactured in 2019? There was a voluntary recall for Corsair SF series power supplies in late 2019 & early 2020. Before buying make sure it isn't in the affected batch otherwise you would need to go through Corsair for a replacement. The person selling it might be selling it for cheap so they don't have to deal with the hassle of shipping it back to Corsair for replacement. You can check if the PSU is in the affected lot by checking first 6 digits of the serial number on the PSU. 194448__ to 201148__. The first two digits are the year (19 is 2019, 20 is 2020) and the second two digits are the week it was produced. 44 is week 44 of that year. If it's before 1944 or after 2011 then it's not affected.
https://forum.corsair.com/v3/showthread.php?t=197081
QuoteThis issue potentially affects units in lot codes 194448xx to 201148xx, manufactured between October 2019 and March 2020
Just now, DaveCad919 said:Case is: Cooler Master MasterBox NR200P
The case lists support for SFX-L power supplies and 130mm for power supply clearance. The Fractal SFX-L PSU is 125mm. Should fit based on the case specs, but depending how the PSU is mounted the modular cables might be in the way as they stick out a little bit from the PSU.
