Cpu temps started going crazy on idle
ognax
Soo it was just normal day playing minecraft. temps were normal too but after 2hours pc started making weird noise and cpu temps were up to 87°c (normally about 60°c when playing minecraft). So i restarted my pc and my idle temps was 60°c (normally 30-40°c on idle) wtf happened? I applied new thermal paste didint help at all 🙂 what should i try. im now trying to troubleshoot it. Hope me luck and if u can help me eny way thx.
Newest windows version.
Cpu: i5-9600k
Gpu: gtx 1660ti
Ram 16gb dual slot
Psu: 550w corsair
Ssd: 250gb
Hdd: 500gb
Ask for more info if needed
<-- Moved to Troubleshooting -->
Please pay attention to where you're posting new threads.
"Black Out"
1tb Samsung 970 Evo | 2x 2tb Crucial MX500 SSD | Fractal Design Meshify S2 | Corsair HX1200 PSU
Dedicated Streaming Rig
 Ryzen 7 3700x | Asus B450-F Strix | 16gb Gskill Flare X 3200mhz | Corsair RM550x PSU | Asus Strix GTX1070 | 250gb 860 Evo m.2
- Check fan speed.
- Check your heatsink mounting pressure (simplest way is to lay the case down, push the heatsink down with your hand and see if temps improve drastically).
- Check CPU voltage (VRMs could be out of whack, supplying too much, or it could be bad bios settings...).
- Temp sensor you are looking at could be defective, check other sensors.
VGhlIHF1aWV0ZXIgeW91IGJlY29tZSwgdGhlIG1vcmUgeW91IGFyZSBhYmxlIHRvIGhlYXIu
^ not a crypto wallet
