Hi I am currently building my gaming PC. I'm almost done but I couldn't find one cables slot.
I use Msi Forge 100R and B450m Mortar MAX , case has ARGB fans and a controller at the back but controller's output cable doesn't fit anywhere on the board. Doesn't Mortar support ARGB
https://linustechtips.com/topic/1321257-argb-cable/
I dont mean to be rude about it, but why wont these fit?
When i ask for more specs, don't expect me to know the answer!
I'm just helping YOU to help YOURSELF!
(The more info you give the easier it is for others to help you out!)
Not willing to capitulate to the ignorance of the masses!
https://linustechtips.com/topic/1321257-argb-cable/#findComment-14608703
6 minutes ago, trkgmssy said:
This cable should go to motherboard, pins you mentioned are for fans I already connected the fans, cable I showed is ARGB controllers output
The picture is to bad to really see, but im about 95% sure the connector i pointed at on motherboard is aRGB connector (output). 😉
And according to the manual (ALWAYS RTFM) they are here:
Sorry the picture is so bad i only now realize thats not the motherboard but the control board. oopsie. sorry.
https://linustechtips.com/topic/1321257-argb-cable/#findComment-14608718
The thing you points is ARGB controller, which is at the back of the case. Sorry for the photo quality my hand shaked I think
https://linustechtips.com/topic/1321257-argb-cable/#findComment-14608724
Yeah my bad i only just realized that.
You might need adapter cables to make them fit, but its as easy as putting right cable to right spot and there are only 3. 😉
https://linustechtips.com/topic/1321257-argb-cable/#findComment-14608731
Documentation on this case is scarce, luckily someone showed the needed manual page in their review:
Source: https://www.youtube.com/watch?v=ES6LVw-cwjs
As we can see here, the case needs a JRAINBOW connector, which the Mortar B450M MAX does not have.
In this scenario, you can only use the LED switch on the front of the case.
They would fit, in the same way this fits:
This hub in the case is only acting like a 'splitter' for the RGB fans, but the needed connector is not on the motherboard.
https://linustechtips.com/topic/1321257-argb-cable/#findComment-14608734
There is a JRGB on the board but it has 4 pin, all of them has metal thing, probably I need an adapter.
https://linustechtips.com/topic/1321257-argb-cable/#findComment-14608735
I'm closing the case then, I will order a cable later thanks
https://linustechtips.com/topic/1321257-argb-cable/#findComment-14608740
