Using 3 cores on my i7 10700k
Solved by unclewebb,
6 hours ago, SorryClaire said:number of processors have been unchecked
Maybe he has not rebooted yet. That is the important part.
You can also select Normal startup, press OK and immediately restart so Windows can find all of the cores.
@Dukedog2001 Your screenshot only shows 3 cores and 6 threads. Your CPU supports 8 cores and 16 threads. Hopefully you can find the missing ones. Did this hard drive come from a previous computer? What CPU did you used to have? You might have had half of that CPU disabled without ever knowing it.
