AMD 7970 Ghz ed VS 670 power ed
hikari
Hi all,
Need your guys opinion on the above.
is getting 7970 Ghz Ed really worth it compared to 670 power ed ?
both are about the same price
for gaming purpose at 1080p
not planning on multi monitor setting
thanks in advance :)
7970 is better.... if you get one around the 670 price go for the AMD card...
CPU: AMD FX 8120 @4.5Ghz - CPU cooler: Cooler Master Nepton 240M Watercooling - Mobo: Asus M5A97Pro - GPU: Sapphire Radeon R9 280X Vapor-X @ 1200Mhz - Memory: Kingston Hyper X 16GBs DDR3 - Storage: Kingston SSD & Seagate Baracude HDD - PSU: Cooler Master V850W PSU- Case: Cooler Master Cosmost II
-- Build Log old PC (HAF XB): 'the Cube': http://linustechtips.com/main/topic/36288-the-cube-cooler-master-haf-xb/ --
Whichever one is cheaper. I was set on 670s for a time but now the 7970s are a bit cheaper so now I'm set on them. Really they trade small blows but with the latest drivers AMD seems to win out by a bit more FPS. The 670, however, is more power efficient.
even after OC the 670 PE ed, do u think 7970 will still outperform ?
An overclocked 7950 will out perform an overclocked 670, a stock 7970 performs on par the a GTX 680.
Overclocked 7970 outperforms everything .
Plus you get 3 games for free with the 7970 .
Also something to be noted, no need to buy a ghz edition , you can buy a regular 7970 and overclock it, but Ghz edition cards do overclock better.
The never settle bundle :
http://www.techpowerup.com/174146/AMD-Also-Announces-Never-Settle-Game-Bundles.html
Performance comparison after the AMD never settle driver update :
http://www.hardwarecanucks.com/forum/hardware-canucks-reviews/57413-amd-12-11-never-settle-driver-performance-13.html
http://www.hardwarecanucks.com/forum/hardware-canucks-reviews/57413-amd-12-11-never-settle-driver-performance-14.html
http://www.legitreviews.com/article/2059/3/
Tom's hardware chart of all GPUs on all games before the driver updates:
http://www.tomshardware.com/charts/2012-vga-gpgpu/19-Tom-s-Hardware-Index-B-Performance,2976.html
Press control+F and paste AMD Radeon HD 7970 GHz Edition .
The 670s are just a bit overpriced for it's performance range.
