As @Moonzystated above, pictures would help a lot. Im guessing you mean the side panels? The back panel to be exact, cause its the one people usually have most problems with unless the case actually got good cable management.
Its probably just all the cables that block it from fully closing.
54 minutes ago, Zuvrem said:
here
tidy up the cables at the back a lil bit, make sure nothing is being pinched
try to flatten it as you move it around, then align the side panel properly to the notches and slide it to close it (usually how it works)
-sigh- feeling like I'm being too negative lately
2 minutes ago, Zuvrem said:
ok
Should be same as this old HP https://support.hp.com/id-en/document/c01684297
Gaming PC:
CPU: Ryzen 5800X3D | Motherboard: Gigabyte B550 Elite V2 | RAM: Crucial 2x16gb, 3200  JEDEC. | PSU: EVGA SuperNova 750 G3 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: Asus Prime RTX 5070ti OC| Sound: Odac + Fiio E09K | Case: Fractal Design R6 TG Blackout |Storage: Kingston Renegade 2TB and Corsair MP510 960gb | Cooling: CPU: Alphacool ST30 420mm rad, Alphacool CPU and GPU Core LT and Core blocks, D5 pump and res combo
Linux PC:
CPU: Ryzen 7700| Motherboard: Asus A620M-CSM | RAM: Crucial Pro 2x48gb, 5600  JEDEC. | PSU: Corsair CX750 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: MSI Gaming X RTX 3090 | Case: Lian Li Dan Cases A3-mATX black |Storage: SN7100 2TB + Samsung 860 EVO 512gb | Cooling: CPU: Thermalright Peerless Assassin Mini Fan(s): Noctua 1x NF-A14x25 Chromax
alright
