OS hot swap
Go to solution Solved by 8-Bit Ninja,
4 minutes ago, Superrockboy57 said:
Hello i bought a laptop motherboard and I want to know if I can just unplug my main pc's SSD with windows on it and plug it into the laptop (and doing this cycle till I get a new SSD)
Technically yes, but your going to have to reinstall drivers every time you swap, and sooner or later something will go wrong and require a full reinstall. I'd suggest you just leave the SSD in whichever machine you need the most
https://linustechtips.com/topic/1317252-os-hot-swap/#findComment-14577101
This isn't hotswap.
Hotswap is when you swap when the PC is on.
Don't swap boot drives. Drivers will clash and you might start seeing bsods.
I could use some help with this!
please, pm me if you would like to contribute to my gpu bios database (includes overclocking bios, stock bios, and upgrades to gpus via modding)
Bios database
My beautiful, but not that powerful, main PC:
prior build:
https://linustechtips.com/topic/1317252-os-hot-swap/#findComment-14577102
Technically you can, but that's not a great idea at all. It also isn't hot swapping.
Main System: Phobos
AMD Ryzen 7 2700 (8C/16T), ASRock B450 Steel Legend, 16GB G.SKILL Aegis DDR4 3000MHz, AMD Radeon RX 570 4GB (XFX), 960GB Crucial M500, 2TB Seagate BarraCuda, Windows 10 Pro for Workstations/macOS Catalina
Secondary System: York
Intel Core i7-2600 (4C/8T), ASUS P8Z68-V/GEN3, 16GB GEIL Enhance Corsa DDR3 1600MHz, Zotac GeForce GTX 550 Ti 1GB, 240GB ADATA Ultimate SU650, Windows 10 Pro for Workstations
Older File Server: Yet to be named
Intel Pentium 4 HT (1C/2T), Intel D865GBF, 3GB DDR 400MHz, ATI Radeon HD 4650 1GB (HIS), 80GB WD Caviar, 320GB Hitachi Deskstar, Windows XP Pro SP3, Windows Server 2003 R2
https://linustechtips.com/topic/1317252-os-hot-swap/#findComment-14577136
