Currently my setup is completely silent. I have replaced all spinning HDDs with SSDs a long time ago and all fans are Noctua NF-A12x25 spinning at 400 rpm. Other fans sometimes had a little bit of clicking from the motor when running at slow speeds.
This is to give you a reference as to the noise level (or lack thereof) I want to achieve.
From your personal experience, is it possible to get a D5 or a DDC down to inaudible levels with PWM control? Or will there always be some amount of noise coming from them? I have had an AIO for a short amount of time and even when turning that pump down to the bare minimum that it would start at, it was still audible.
Flow and cooling are not a concern. I am fine with a bit of noise once I actually put some load on my PC while gaming. So I will regulate the pump and fans with a curve. I want it to be completely silent while browsing though.
So long as there's no bubbles in the loop (usually work their way out in a few days), a D5 with the anti-vibration mounts is really quiet, and I run mine at max RPM. I'd assume you could get one nigh inaudible even without fan noise to cover it up. Speaking of which, HardwareLabs makes a bunch of their rads specifically built for sub-800rpm fans, so you probably wouldn't need to ramp the fans even under load.
You will have to hope you lucked out and got a GPU with no coil whine/buzz though. Both my Radeon VII and now 2060 Super audibly buzz/buzzed on waterblocks, since there's no fan noise to cover it up. That's only under higher GPU load though, heavier compute stuff or full gaming load though.
Gaming PC NAS Laptop Workstation
CPU: i5 12600KF 6P+4E Ryzen 7 3700X M4 SoC 4P+6E Xeon X5690 6c12t
Cooler: Noctua NH-D15S Wraith Stealth w/NF-A9 Passive Apple CPU Cooler
Motherboard: ASRock Z690 ITX/ax ASUS Pro B550M-C/CSM Apple J713AP Mac-F221BEC8 (Mac Pro 5,1)
RAM: 2x16GB 3600Mhz DDR4 2x16GB 2400MHz DDR4 24GB Micron LPDDR5 4x8GB 1333MHz ECC DDR3
GPU: Sapphire Pulse Radeon 9060 XT 16GB Radeon WX2100 M4 SoC 10C Radeon RX 5700
Storage: 1TB MP34 + 2TB P41 500GB SSD + 2x4TB IronWolf Pro in ZFS Mirror Apple AP0512Z 1TB Crucial MX500
ODD: LG WH14NS40 None LG GP65NB60 USB DVD Writer Don't know
PSU: EVGA 850W GM Silverstone SST-TX300 53.8Wh LiPo Battery Delta DPS-980BB
Case: Silverstone Sugo 14 Dell Inspiron 530S Mac16,12 chassis (13" MBA) 2009-2012 Mac Pro "Cheese Grater"
OS: Gentoo Linux TrueNAS Scale macOS 26 Tahoe Fedora Linux
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 14" M5P MacBook Pro (work) - iPhone 17 Pro - Apple Watch S11
Other Misc Devices: iPod Video (Gen 5.5E, iFlash Solo w/128GB SD Card, Rockbox), Nintendo Switch
Vehicles: 2002 Ford F150, 2003 Harley-Davidson Sportster 1200, 2022 Kawasaki KLR650, 1994 DR350SE
You can make an AIO quieter by having the tubes downwards or having the rad top-mounted. I know this is reciting the famous GN video, but I have been a serious fan of them and actually watched and understood the video in its entirety. Having tubes mounted on top can cause some pump whine or gurgle noises, but can be eliminated by making sure air is out of the pump by having the AIO's tubes on the bottom.
Fuck you scalpers, fuck you scammers, fuck all of you jerks that charge way too much to tech-illiterate people.
Unless I say I am speaking from experience or can confirm my expertise, assume it is an educated guess.
Current setup: Ryzen 5 3600, MSI MPG B550, 2x8GB DDR4-3200, RX 5600 XT (+120 core, +320 Mem), 1TB WD SN550, 1TB Team MP33, 2TB Seagate Barracuda Compute, 500GB Samsung 860 Evo, Corsair 4000D Airflow, 650W 80+ Gold. Razer peripherals.
Also have a Alienware Alpha R1: i3-4170T, GTX 860M (≈ a 750 Ti). 2x4GB DDR3L-1600, Crucial MX500
My past and current projects: VR Flight Sim: https://pcpartpicker.com/user/nathanpete/saved/#view=dG38Jx (Done!)
A do it all server for educational use: https://pcpartpicker.com/user/nathanpete/saved/#view=vmmNcf (Cancelled)
Replacement of my friend's PC nicknamed Donkey, going from 2nd gen i5 to Zen+ R5: https://pcpartpicker.com/user/nathanpete/saved/#view=WmsW4D (Done!)
In my experience (2 custom loops in the past year), there will always be some noise.  The main benefit noise-wise of custom water cooling loops is that baseline noise you hear is pretty much it.  The fans never have to ramp up because the system is so efficient.  So you'll always hear that low level hum, but you'll pretty much never hear anything more than that.
PS: One of my water cooled systems is sitting about 8 feet from me.  I can't hear it.  If you want to eliminate noise completely, that might be an option (though I recognize that it'd be a difficult and weird option to exercise)
#Muricaparrotgang
Folding@Home Stats | Current PC Loadout:
Small                        Bigger				Biggerer				Biggest
Fractal Design Focus G       NZXT H1				Lian LI O11 Dynamic XL			Fractal Design Meshify C
FX-8320                      Ryzen 3 3200G			Ryzen 5 3600				Ryzen 7 3700X
120mm AIO                    120mm AIO				Custom 280mm loop			Noctua NH-D15
A motherboard                ASRock B450 mobo			MSI x570 mobo				MSI x570 mobo
16gb DDR3                    16gb DDR4 @ 3200			16gb DDR4 @ 3200			16gb DDR4 @ 3600
a melange of HDDs/SSDs       WD 1tb m.2				WD 500gb m.2				WD 1tb m.2/2tb HDD
PNY GTX 1070 x2              GTX 1070				GTX 1070 FE				MSI RTX 2080 TI
some 650w PSU                650W SFX-L 80+ Gold		MSI RTX 2080 Super			EVGA SuperNova 750w 80+ GOLD
								Corsair RM850x 80+ GOLD
D5 with rubber isolator is extremely quiet. I can’t hear my pump at all with the side panel on. I run my pump at 1500 rpm at idle, and my fans at 600, also noctua, 140 mm. It’s dead quiet at idle as I turn all fans off except my top rad fans when at idle which means d5 at 1500 rpm, 3 140 fans at 600rpm. As the GPU warms up and hits 45c, pump ramps up, fans ramp up, front rad fans start to spin 2x120 as intake), rear (intake) and bottom (intake) start to spin as well and they all ramp up with GPU temp.
I control all by the GPU because I have no use case that will dump more heat into the system then just the top 420 rad with 600rpm can handle, especially given the water volume to act as a buffer, larger water volume = more stable temps and much slower temp rise of the liquid. My loop has a bit more than 1/3 gallon of water in it. The only thing I do that can get water temps to start rising in any meaningful way is gaming for 30 minutes +. With both CPU and GPU dumping heat into the system, the top fans at 600 are not enough. So all of them spinning at ~900 is the sweet spot for low (almost inaudible) noise, and maintain GPU under 50c and CPU under 60ish.
TLDR; yes. It’s possible. Not cheap, but possible. If you want dead silent, they make cases with integrated heat pipes that run to very large heat sinks built into the case, no fans needed. But this would only be for a relatively low power build; a buddy had a Ryzen quad core in such a case, works great! And used an external power supply that also has no fan.
That's what I was thinking. Under load water cooling will be quieter than air cooling. But when idleing the pump still needs to run.
No need for passive cooling. My NF-A12x25 at 400rpm-600rpm are fine for idle and also fine to ramp up a bit under load. It's the pump at idle that I am concerned about.
The AIO I had and ran at minimum spin up speed of the pump had this barely noticeable humm from the motor (not bubbles). It was most obvious when turning off the computer or unplugging the pump for a second and it's suddenly gone.
D5 with rubber isolator is pretty damn quiet.
Yeah you can get a 12V D5 pump down to inaudible levels without that much difficultly or insulation required.  Especially with vario/PWM you can dial it back to be inaudible unless your head is 3 inches from it.   Foam pad underneath it, set it to 2/5...good to go.
I just went through making a 24V D5S pump inaudible.  It took a shitload of insulation and having it fully suspended (except for the inlet / outlet tubing).
Workstation:  9800X3D|| Asus X670E ProArt Creator || MSI Gaming Trio 4090 Shunt || T.Force 7800CL34 || Corsair AX1600i@240V || whole-house loop.
LANRig/GuestGamingBox: 13700K @ Stock || MSI Z690 DDR4 || ASUS TUF 3090 650W shunt || Corsair SF600 || CPU+GPU watercooled 280 rad pull only || whole-house loop.
Server Router (Untangle): 13600k @ P-Core only || ASRock Z690 ITX || All 10Gbe || 2x8GB 3200 || PicoPSU 150W 24pin + AX1200i on CPU|| whole-house loop
Server Compute/Storage: 10850K @ 5.1Ghz || Gigabyte Z490 Ultra || EVGA FTW3 3090 1000W || LSI 9280i-24 port || 4TB Samsung 860 Evo, 5x10TB Seagate Enterprise Raid 6, 4x8TB Seagate Archive Backup ||  whole-house loop.
Laptop: HP Elitebook 840 G8 (Intel 1185G7) + 4070 RTX Thunderbolt Dock, Razer Blade Stealth 13" 2017 (Intel 8550U)
One of my builds is dead sielent at idle or usual office work, it has i5 9400f and vega 56, I is cooled with a monoblock and a vega nano full cover waterblock. It has a ekwb xe240 (the fat one) with 2 nf-a12x25 for the pump - some chinese ddc style pump only 10watts so it runs of the motherboard header.
However under gaming load it is the coil whine that makes most noise.
the link is in my signature
CPU: i7 8700K OC 5.0 gHz, Motherboard: Asus Maximus VIII Hero (Z170), RAM: 32gb Corsair Vengeance RGB 3200 mHz, GPU: Asus Strix OC gtx 1080ti, Storage: Samsung 950pro 500gb, samsung 860evo 500gb, 2x2Tb + 6Tb HDD,Case: Lian Li PC O11 dynamic, Cooling: Very custom loop.
CPU: i7 8700K, Motherboard Asus z390i, RAM:32gb g.skill RGB 3200, GPU: EVGA Gtx 1080ti SC Black, Storage: samsung 960evo 500gb, samsung 860evo 1tb (M.2) Case: lian li q37. Cooling: on the way to get watercooled (EKWB, HWlabs, Noctua, Barrow)
CPU: i7 9400F, Motherboard: Z170i pro gaming, RAM: 16gb Corsair Vengeance RGB 3200 mHz, GPU: Sapphire Vega56 pulse with Bykski waterblock, Storage: wd blue 500gb (windows) Samsung 860evo 500Gb (MacOS), PSU Corsair sf600 Case: Motif Monument aluminium replica, Cooling: Custom water cooling loop
