RX 570 idle temp increased by 20 °C with two monitor, is this normal?
Solved by mariushm,
5 hours ago, fakhri2k said:If I may ask, so the card is fine running for extended amount of time while the memory clock stays at max speed? Because I mainly use this computer for my university work for about 14 hours a day doing light work such as google docs, online classes or browsing using both monitor.
Yes, it's fine.
It's a card designed for gaming, where both gpu and memory runs at near 100% for hours at a time.
The only reason they reduce the frequencies is to save power and make less heat, it's not needed for the memory chips to have a long life. The chips don't degrade in any significant amount, the card would still last you 10 years+ as it is running now.
