VAT C code help
Go to solution Solved by C2dan88,
When you first set a with scanf that line should be
scanf("%f", &a);
Your code should be
#include <stdio.h>
int main()
    float a, sum;
    printf("\nEnter Value: $");
    scanf("%f", &a);
    sum = a * 0.175;
    printf("VAT: $%.2f", sum);
    sum = a - sum;
    printf("     New Value:  $%.2f", sum);
So i was told to write a code to calculate VAT , but it doesn't work as i want it to, for example when i put a value of 100 it should say 17.5 but instead of that it says 17, it doesn't show decimal places for some reason, if anyone could help that would be great .
And also how do i so the function repeats again when you type R and exit when you click anything else .
https://linustechtips.com/topic/1314977-vat-c-code-help/
You've declared both a and sum as integers which aren't decimal numbers. Not sure what the behaviour of C is when multiplying an int by a float, but it's probably the underlying cause of your problem.
Also the %d code in your printf statement is for integers, not floating point numbers.
[Edit] It seems that int * float will give a float. I think it's your print statement that's the issue. Try changing it to %f or something.
Crystal: CPU: i7 7700K | Motherboard: Asus ROG Strix Z270F | RAM: GSkill 16 GB@3200MHz | GPU: Nvidia GTX 1080 Ti FE | Case: Corsair Crystal 570X (black) | PSU: EVGA Supernova G2 1000W | Monitor: Asus VG248QE 24"
Laptop: Dell XPS 13 9370 | CPU: i5 10510U | RAM: 16 GB
Server: CPU: i5 4690k | RAM: 16 GB | Case: Corsair Graphite 760T White | Storage: 19 TB
https://linustechtips.com/topic/1314977-vat-c-code-help/#findComment-14558186
Also you need to change the %d's in printf and scanf since %d will only read/display integers as well.
F@H
GPD Win 2
https://linustechtips.com/topic/1314977-vat-c-code-help/#findComment-14558193
That's because you're using an int.
int is a variable type that holds a number, but only whole numbers, not numbers with decimal points. Because you're working with money, you obviously do want those decimal point, so change the variables that need a decimal point to a float/double.
https://linustechtips.com/topic/1314977-vat-c-code-help/#findComment-14558202
4 minutes ago, Helomegussta said:
so what do i need to do , do i just change all int's to float or how does it work?
Probably all you need to do is replace your %d with %f (as I discovered above, float * int will become float):
https://www.tutorialspoint.com/c_standard_library/c_function_printf.htm
For good measure, however, since you are dealing with floating point numbers it would be "better" code to also declare them as a floating point type.
https://linustechtips.com/topic/1314977-vat-c-code-help/#findComment-14558203
C will do implicit conversion between types
To print a float value youll need to %f of some sort, depending on how many values you want to output.
Eg.
printf("%.2f", floatVal);
https://linustechtips.com/topic/1314977-vat-c-code-help/#findComment-14558205
4 minutes ago, tikker said:
Probably all you need to do is replace your %d with %f:
when i change %d to %f this is what am getting when i enter value 100
https://linustechtips.com/topic/1314977-vat-c-code-help/#findComment-14558210
scanf("%f", &a);
Your code should be
#include <stdio.h>
int main()
    float a, sum;
    scanf("%f", &a);
    sum = a * 0.175;
    sum = a - sum;
https://linustechtips.com/topic/1314977-vat-c-code-help/#findComment-14558236
12 minutes ago, Helomegussta said:
when i change %d to %.2f in scan and print statements am getting 0 for some reason.and int a,sum to float a,sum
What @C2dan88 says. The "1" you include in scanf seems to make it only read one character from a quick google (I don't really use C). Time to dive into C's documentation 😉
https://linustechtips.com/topic/1314977-vat-c-code-help/#findComment-14558239
scanf("%f", &a);
Your code should be
#include <stdio.h>
int main()
    float a, sum;
    scanf("%f", &a);
    sum = a * 0.175;
    printf("VAT: %.2f", sum);
    sum = a - sum;
so i didn't have to write .2f at the scanf("%ld", &a)
https://linustechtips.com/topic/1314977-vat-c-code-help/#findComment-14558242
scanf("%f", &a);
Your code should be
#include <stdio.h>
int main()
    float a, sum;
    scanf("%f", &a);
    sum = a * 0.175;
    sum = a - sum;
but thank you very much , i been trying to figure this out for 8 hours now
https://linustechtips.com/topic/1314977-vat-c-code-help/#findComment-14558244
It's a good learning experience.
A thing that no one has noted though, it's always important to remember the pitfalls of using floats/doubles with currencies  (i.e. Be careful if you are using them in anything that might be mission critical/needs accurate values).  Floats do handle decimals, but they are based on a binary system (and are finite).
For floats/doubles you can only do decimals in the form of 1/(2^n)...e.g. 0.75 = 1/2 + 1/4 = 0.11(binary), 0.5625 = 1/2 + 1/16 = 0.1001
The problem is when you have something like 0.1 or 0.9
e.g. 0.9 = 1/2 + 1/4 + 1/8 + 1/16 + 1/32 + .... but since you are limited in the amount of numbers, 0.9 becomes 0.8999999999
That is why you have to be careful around floating points because if you go 0.9 + 0.9 + 0.9 + .... (and do it many many times) you will eventually end up with a small amount off than what the true value would be).  For the purposes of learning, it doesn't make a difference really and I'd argue in a lot of situations it won't matter as much (like video games where you can't purchase the currency).
3735928559 - Beware of the dead beef
https://linustechtips.com/topic/1314977-vat-c-code-help/#findComment-14558928
Be so careful when calculating VAT.  You've spent 8 hours, but I've seen people spent several days on resolving issues in production as a result of VAT miscalulation.
The part where I've seen colleagues come unstuck is with rounding a value.  It is generally accepted that currency calculations should always round down (due to the fact that you cannot have a fraction of a penny in a decimalised currency system).  Assuming that your application is being written for a business and is non-trivial, check with your finances team how they calculate VAT.  Even better - get a decent sample of invoices you've processed on a previous system and run it through your algorithm to check it matches up.
If your business rounds down, make sure to round down after each calculation which may cause greater than two decimal places.  Here's an example where I've seen colleagues mess up:
  • Invoice X contains 2 units of Product Y at £9.99/unit
  • First, we calculate VAT => 9.99 + (9.99 * 0.2) = 11.988
However, we sold two units, so we should multiply this by two, right?
  • 11.988 * 2 = 23.976
If we just round this down to £23.97, depending on how your business handles VAT, you're now £0.01 over.  If you use standard mathematical rounding rules, rounding up to £23.98, you're now £0.02 over.
So let's go back and round that inc VAT value before we multiply by two...
  • 11.988 ≈ 11.99 (standard mathematical rounding rules)
  • 11.99 * 2 = 23.98
We're still £0.02 over.  This is because we should have rounded down - going against mathematical rules.  If we do that instead...
  • 11.988 ≈ 11.98 (overriding mathematical rounding rules)
  • 11.98 * 2 = 23.96
Now we have the inc VAT value we expected.
It may seem insignificant when we're speaking about this amount of money, but in our scenario the application was processing hundreds of invoices each day using this flawed logic.  Luckily, our accountancy software calculated VAT independently, so we were able to pick up on it when the inbounds funds didn't match rather than when we filed our taxes.
VAT is really confusing, especially when you're learning.  If you can offload your VAT calculation onto a system which has been tried and tested, I'd recommend it.
https://linustechtips.com/topic/1314977-vat-c-code-help/#findComment-14569727
Isn't it rather that financial software would usually add all the "without tax" prices first, round if needed, then take the 0.2 of that?
F@H
GPD Win 2
https://linustechtips.com/topic/1314977-vat-c-code-help/#findComment-14570325
That’s another way of doing it, sure.  I don’t think there’s any set way of doing it per-se, I’d just like to express caution that it can be a very tricky business and is easy to get wrong.
https://linustechtips.com/topic/1314977-vat-c-code-help/#findComment-14576873
