How many fans
Go to solution Solved by TylerDurden!,
Just now, Da_Big_Daddy said:
4 case fans ? +1 the psu fans?
You can literally use as many fans as you can fit into whatever case you are using.  You can use a splitter and hook up multiple fans to the same header, or you can hard wire them to power, or run them off of a fan controller.
I have a question i d like to buy this motherboard Gigabyte B450M DS3H V2 and i want to install some fans on the case as well. My question is how many fans can i connect in this motherboard and if it doesnt satisfy me can install more with an extra device or do i have to buy a different motherboard (i would like to install 6 fans idk why i just do)
https://linustechtips.com/topic/1314487-how-many-fans/
5 if u include cpu fan and pump headers
THIS IS MY SIGNATURE
https://linustechtips.com/topic/1314487-how-many-fans/#findComment-14554200
https://linustechtips.com/topic/1314487-how-many-fans/#findComment-14554210
and how do i know if i need a 3-pin 4-pin or 6pin fan?? i cant find it in the mobos specs
https://linustechtips.com/topic/1314487-how-many-fans/#findComment-14554218
