Routers with cable antenna and frequency
ElijahAnti
Have a Skyworth router. It's connected via coaxial, thinking it can be replaced by regular ones and connect via coaxial adapter if it is possible to replace. Its connected to an antenna like television and not physically lined to the server.
My other thought is getting different brand if 'em but there might be security problems and such.
Its hard to say if you can just replace this with your own router instead because while there are cable modems/routers available many ISP´s block devices that are not their own.
You would need to ask your provider if they allow private modems and what you need to look for when you wanna get one.
Most of the time you have to use modem from the ISP.
If you want better wifi connectivity, just add another router acting as a slave / access point mode.
Yes you can get routers with Coax /DOCSIS 3.1,3.0
CPU: Ryzen 5800X3D | Motherboard: Gigabyte B550 Elite V2 | RAM: G.Skill Aegis 2x16gb 3200 @3600mhz | PSU: EVGA SuperNova 750 G3 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: Red Devil RX 7900XT | Sound: Odac + Fiio E09K | Case: Fractal Design R6 TG Blackout |Storage: MP510 960gb and 860 Evo 500gb | Cooling: CPU: Noctua NH-D15 with one fan
FS in Denmark/EU:
Asus Dual GTX 1060 3GB. Used maximum 4 months total. Looks like new. Card never opened. Give me a price.
-> Moved to Networking
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
Why do you wish to do this? Was the current unit provided by the ISP?
Who is your ISP? Have you tried contacting them about compatible replacement models?
Cause this thing can't handle even 2 dhcp client, maybe old or bc no Qos.
Also it can't wps our wifi extender
What you have there looks like a cable internet gateway (combo modem, router, access point).
If this unit is provided by your ISP and directly interfaces with the WAN uplink, you need to get in contact with your ISP to find out if it can be replaced and which device(s) they approve as replacement.
