with aRGB stuff, i assume that the header itself just has the 5v and gnd pins go straight to the nearest power rails.. i'd have to measure a motherboard to test this, and i'm not about to disassemble my pc to probe stuff.. but i assume there's no reason why you couldnt...
also, isnt aRGB limited by number of LEDs, rather than current draw?
https://linustechtips.com/topic/1310762-argb-to-psu/#findComment-14523720
4 hours ago, NorKris said:
If ur planing to run more amps than MB / controller provides.  Can you run  5v and ground from PSU directly and the signal wire from MB / controller?
any1 try'd this?
https://linustechtips.com/topic/1310762-argb-to-psu/#findComment-14524098
no it just repeats its self.
mb header is max 3 amps
you can pull power form the psu and the data and ground from the mb
rgb on the other hand is a bit different as you need to get a repeater then get power form the psu to the repeater just like injecting power in long strips in rooms.
Edited by thrasher_565
https://linustechtips.com/topic/1310762-argb-to-psu/#findComment-14524103
7 hours ago, NorKris said:
power and ground from the psu right?
Yesterday i actually found a pic of this config that you posted, and i wanted to ask you about that. put then  Crazy Joe pres 45 was speaking  and i fell asleep 😛
there a quote button if you want people to respond.
you may or may not need gourd but it wont hurt.
https://linustechtips.com/topic/1310762-argb-to-psu/#findComment-14525334
I tested it now with almost 5A in ARGB's. That Sata connector gets HOT
5v and ground from SataPower and the signal wire from the CM ARGB controller
https://linustechtips.com/topic/1310762-argb-to-psu/#findComment-14525341
you have 5 amp of strips? or argb devices? maybe split them up in to two sets with 2 sata power.
i think some one said sata connector should do like 20ish amps and i dont no about the wire gauge coming off of it. should do 5amps thow i would think.
https://linustechtips.com/topic/1310762-argb-to-psu/#findComment-14525351
oh looks like its only 4.5 amps of sata and more for molex my bad. good to no.
https://forums.tomshardware.com/threads/does-a-molex-connector-provide-as-much-power-as-sata-power-connector.182242/
https://linustechtips.com/topic/1310762-argb-to-psu/#findComment-14525367
im at 4,56 in my test setup! 😄
judging from the heat, the "bottleneck" is at the SataConnector not at the thin ARGB wires.. they cool and good
https://linustechtips.com/topic/1310762-argb-to-psu/#findComment-14525373
i would do 2 sets to be safe. or 1 molex
https://linustechtips.com/topic/1310762-argb-to-psu/#findComment-14525382
9 hours ago, NorKris said:
another interesting find: it only gets hot when the LED's are white
ya solid white or red i think is the most demanding. i guess white because it uses all 3 colors. ya ill have to update my guide on the different of sata and molex.
https://linustechtips.com/topic/1310762-argb-to-psu/#findComment-14526852
