Please help me choose between these 2 streaming devices
james_bond
I am planning to buy a streaming device within a couple of months.
I have never used any such device before.
Suppose you are the customer which one of the following device will you choose/buy ?
Please also mention the reason behind your decision.
Fire TV Stick
Mi TV Box
Note : I do not have a 4K TV so I wont be able to take advantage of that feature.
Using only Linux since 2007. Not a single MS Windows or Mac client at home.
Any ideas ?
I have no need or want for them, but if I had to I’d buy both to test them out to see which does what I want it to do.
If I buy them both there is no point in doing research. If the picture quality is good in both the devices the only thing that is left for consideration is longevity. I created this topic so that people who have used both devices can give me some tips.
Strictly for streaming? Firestick, no brainer.
It's cheap and works, I have three. It breaking is pretty much unheard of.
Desktop: 7800x3d @ stock, 64gb ddr4 @ 6000, 3080Ti, x670 Asus Strix
Laptop: Dell G3 15 - i7-8750h @ stock, 16gb ddr4 @ 2666, 1050Ti
@Andreas Lilja
Okay I will buy a Firestick.
I just want to gain some knowledge. Under which circumstances is the Mi TV Box better than the Firestick ?
