optimum airflow be quiet pure base 500
Solved by Stahlmann,
2 minutes ago, Ali90 said:Should I use the 2 140mm that came with the case and get extra one or just get 3 "better" 140mm.
What 140mm fan would you suggest.
Thanks.
The beQuiet fans are very good, no need to get better ones. Just get another Pure Wings 2 140mm PWM fan.
Featured Topics
IBM_THINKPAD_R51 ·
Posted in Servers, NAS, and Home Lab0 -
3
1
Beeswitt ·
Posted in Troubleshooting1 -
3
