arctic p12 vs Corsair ML120 Pro
Wateeeerrr
Which fan is better? Its because I am looking at the corsair 4000d case and it has the Corsair ML120 pro fans and Im thinking if I should add on to the case or remove the Corsair ML120 pro as a whole.
P12s are for static pressure, ML120 are, iirc, a mix of both pressure and airflow fans. I would lean more to the ML120 side unelss you are pushing through a radiator. I have 2 ML140 in the front of my case and they run quiet and have had no issues with temperatures.
Edit: is this the 4000d airflow?
finally escaped fm2+
I know p12s are for static pressure but people are reccomending them as case fans too so I was debating to replace all of the fans or keep them, so thank you.
p12's are great all-around options for basically anything. They're most notable for static airflow, but they're just good fans, especially for the price. The ml120 pros aren't bad either. I wouldn't remove them unless you care about the aesthetic or want fan uniformity
I am NOT a professional and a lot of the time what I'm saying is based on limited knowledge and experience. I'm going to be incorrect at times.
Motherboard Tier List                   How many watts do I need?
Best B550 Motherboards             Best Intel Z490 Motherboards
PC Troubleshooting                      You don't need a big PSU
PSU Tier List                                Common pc building mistakes
PC BUILD Guide! (POV)              How to Overclock your CPU
will it be bad if there were two diff types of fans?
Not really. I don't know what you mean about that, but it shouldn't have very many detrimental effects.
im talking about the ml120 pros with the arctic p12s together in one case
I would buy the Corsair 4000D and see if you like the fans that come with it.  If you do, buy more of them. I can tell you about a decade ago, I would buy fans based on someone else’s recommendation or a review I saw, to only be extremely disappointed. Someone would claim “these are better than Noctua” as often said, but all I hear is an annoying buzz coming from the hub, or they would just drone. It did spark an unhealthy obsession and I also figured out I am much more sensitive to noise than most.
So, I would see if you like the fans in the case first. If they bother you, then look at something else. Maybe buy 1 of a different model, if you like it, buy more of them.
We recommend P12 because it's decent and cheap, not that you should replace every fan with them.
Desktop benching:
@Blxnkd Exactly this.
  • 2 weeks later...
buy  arctic's new released p120 Argb...
Better RGB than ML, better performance too
