ITX/MATX case for 336mm GPU?
Kitsan
Im trying to find the smallest case that will fit an MSI RTX 3080 Suprim X - 336 x 140 x 61 mm, I did want a smaller GPU but im just happy to even have a 3080!
So far i've found the Kolink Citadel Mesh and Lian Li O11 Dynamic Mini, I don't mind the Kolink but would prefer something a bit more premium and although the Lian Li is more premium... it's full ATX sized.
Anything else to consider?
Monitor: Alienware AW2518HF CPU: 9900K @ 5.1GHz Heatsink: 2x360MM Custom Loop GPU: MSI GeForce RTX 2080 Ti GAMING X TRIO RAM: Patriot Viper Steel DDR4 2x8GB 4400Mhz Mobo: Asus Maximus XI Gene Case: Fractal Design Meshify S2 PSU: Corsair RM1000x Storage: Seagate Firecuda 510 2TB M.2, Adata XPG SX8200 PRO 256GB M.2
I've seen 3090 FEs in a Coolermaster NR200. Not sure what their length is compared to yours.
Project Hot Box
Oppbevaring
Why is the 5800x so hot?
2 minutes ago, Voluspa said:
Coolermaster NR200
https://www.coolermaster.com/catalog/cases/mini-itx/masterbox-nr200/#specifications
Officallly 6mm (1/4" too short)
Here's a pretty comprehensive list of SFF cases
https://docs.google.com/spreadsheets/d/1AddRvGWJ_f4B6UC7_IftDiVudVc8CJ8sxLUqlxVsCz4/edit#gid=1459265577
The Sliger SV590 seems to fit everything but it's $260
CPU i7-4790k    Motherboard Gigabyte Z97N-WIFI    RAM G.Skill Sniper DDR3 1866mhz    GPU EVGA GTX1080Ti FTW3    Case Corsair 380T
Storage Samsung EVO 250GB, Samsung EVO 1TB, WD Black 3TB, WD Black 5TB    PSU Corsair CX750M    Cooling Cryorig H7 with NF-A12x25
Oof that spreadsheet is nice!
This case looks perfect from that list but I can't seem to find it available: https://www.jonsplus.com/products/i100pro-sg.html
Has anyone seen this for sale anywhere? (I've emailed them to ask)
Looks like a Chinese only case. A lot of the cases on the list are from that part of the country.
It sucks because most cases can fit about a 330mm gpU (where most of the other cards are), but yours is a 1/4" too long. I'm not sure if that 1/4" is mostly plastic shroud or not though.
I contacted them directly and as luck would have it overclockers.co.uk which is owned by caseking have placed an order! It is due to arrive in mid-March
Overclockers staff seemed to be unaware of this but they checked and confirmed the above 😄
I can confirm that it is PCB and backplate on the Suprim X, so it's not like I could remove the shroud and it would fit 😞
