10G SFP Cards. How do they work when you daisy-chain connections?
Solved by Eigenvektor,
Normally all of your devices should be connected to the switch. They'd all receive IP addresses from the one DHCP on your network. Having more than one DHCP on the same network is a recipe for disaster.
If you connect it to the NAS instead, then you'd also have to configure NAT on the NAS, which means the NAS is then used as a router and is part of two networks, while your PC is on a separate network from the switch. In that case the NAS could have a DHCP for the second network. Not an ideal solution, really.
