Hello guys I am from pakistan
I bought dell optiplex 7010 pc
Like 4 months ago
Specs
I7 3770
Mobo dell 0yxt71
16gb ddr3 1666mhz
600 watt thermal take tier2
Rx 470 sapphire nitro plus 4gb
1 TB n 230gb hdd
After it I changed my case and did research on front io and everything worked
Now I have like money rs 5000 to 6000 thousands
I want to know which thing should I buy
Motherboard or monitor
Performance is not issue for now
Pros of motherboard
I will get vast amount of customization, settings and ui bios
And get free of front io connection things
Pros of monitor
I have big sized led and more resolution and can oc it
What you guys think
Right now I have 1366x768
19inch led monitor
Motherboad I have only 3 satas can't use 3rd one cuz of gpu size and no bios settings and cpu fan settings
So right now can't upgrade to ssd
https://linustechtips.com/topic/1300809-motherboard-or-monitor/
I bought dell
Like 4 months ago
Specs
I7 3770
Mobo dell 0yxt71
16gb ddr3 1666mhz
1 TB n 230gb hdd
Pros of motherboard
Pros of monitor
What you guys think
19inch led monitor
3 sata ports are enough, 1ssd + 1hdd + 1optical drive ( which you don't really need )
Plus there are angled sata cables that maybe help you squeeze the cable under the card. Need photos
Also you didn't need to change the case since this is just a budget PC, waste of money the original case is pretty enough
https://linustechtips.com/topic/1300809-motherboard-or-monitor/#findComment-14443438
No no I bought the case thats not a case in this thing
The sapphire card is big and I have 2 angled sata cable
Problem is all 3 satas are in line form so all are under gpu also close so the cables angle is covered the 3rd sata port which is the center one so that why
https://linustechtips.com/topic/1300809-motherboard-or-monitor/#findComment-14443452
Post photos
https://linustechtips.com/topic/1300809-motherboard-or-monitor/#findComment-14443468
