Vertical GPU mount for Corsair crystal 280x
I'm planning a build using a 3060ti in the Corsair Cyrstal 280x, but I wanted to vertically mount my GPU but I am not sure if this 4 slot vertical GPU I found on amazon mount will fit within the case let alone hold the GPU without bottom fans https://www.amazon.com/dp/B08KRRT64X?tag=pcpapi-20&linkCode=ogi&th=1&psc=1 this is the vertical GPU mount so if anyone has this config or can do the math for me could this fit?
I doubt the part will fit, or at least not easily. The case supports 4 slots. iIRC each slot is ~20mm wide, total 80mm. The part is ~140mm "wide".
  • 10 months later...
  • 1 year later...
Hey!. This looks awesome. I have the same case and a TUF 3080Ti and it basically burns. Did you have to make a cut in the case? I am planning of printing your piece.
