I dont want to use screws and nails. Whats the best way to mount a power strip, my monitors power bricks and a cable modem under my desk? Ive tried Velcro strips but they tend to loose adhesion after a while. Though I didnt try the industrial stuff.
https://linustechtips.com/topic/1298895-desk-cable-management/
3M wall mounting tabs, I've hanged hooks with them that held up fifty pound bags at some points, they can be removed when need be too.
AMD blackout rig
cpu: ryzen 5 3600 @4.4ghz @1.35v
gpu: rx5700xt 2200mhz
ram: vengeance lpx c15 3200mhz
mobo: gigabyte b550 auros pro
psu: cooler master mwe 650w
case: masterbox mbx520
fans:Noctua industrial 3000rpm x6
https://linustechtips.com/topic/1298895-desk-cable-management/#findComment-14428819
Just got a pack of these and I'm pretty satisfied with them https://www.amazon.com/gp/product/B07RQCXCR2/
Corps aren't your friends. "Bottleneck calculators" are BS. Only suckers buy based on brand. It's your PC, do what makes you happy.  If your build meets your needs, you don't need anyone else to "rate" it for you. And talking about being part of a "master race" is cringe. Watch this space for further truths people need to hear.
https://linustechtips.com/topic/1298895-desk-cable-management/#findComment-14428824
For holding stuff to a desk, this shit is the tits. If you apply it properly and use the right amount of it, it will have a stupid amount of hold. Just don't use too much or your life will become hell trying to remove whatever you slapped on.
As for cables themselves, I've been using these and they're fine. The adhesive is decent enough on a smoother surface as long as you hulk it on when you apply it and don't yank on it too much.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/1298895-desk-cable-management/#findComment-14428839
wires are not the issue. I have some of those square mounts that you stick a zip tie thru. Its the Modem, power bricks and such.
https://linustechtips.com/topic/1298895-desk-cable-management/#findComment-14428854
Zip tie the velcro or screw it to the table wood to make it permanent.
https://linustechtips.com/topic/1298895-desk-cable-management/#findComment-14428874
The velcro I have used has failed. I use Zip ties but that only helps for the wires. Screws are not something Im willing to use.
https://linustechtips.com/topic/1298895-desk-cable-management/#findComment-14428889
I've never had an issue with the 3M Command picture hanging strips, used in sufficient quantities.
https://linustechtips.com/topic/1298895-desk-cable-management/#findComment-14428894
My monitors power brick sits on the underside of my desk with doubble sided tape.
“Remember to look up at the stars and not down at your feet. Try to make sense of what you see and wonder about what makes the universe exist. Be curious. And however difficult life may seem, there is always something you can do and succeed at.
It matters that you don't just give up.”
-Stephen Hawking
https://linustechtips.com/topic/1298895-desk-cable-management/#findComment-14429235
