Modular Power Supply Cable Identification
Does anyone have reliable resources to identify what cable is for which PSU? I got my Seasonic RMA but don't know which sata cables are for the Corsair and which are for the Seasonic and while I'm at it I'd like to sort through all of these and bag them separately which I should have been doing to start with.
There are at least 5 different supplies these could go to but luckily 3 of them are corsair.
I figured we could get a compilation of knowledge here because I'm sure this is a common situation and I can't find much useful info online. Links guides anything. Thanks
*I've come to the conclusion that a knowledge base is prone to errors so I figured it out myself.
*edit: I got it figured out using several different methods mentioned here and deductive reasoning. Once I figured out which ones were corsair I knew where to look. Did some multimetering and figured out the 3v and 5v were right but I must have shorted 12v to ground and the whole thing shut off so going off that much being right I figured at worst there would be less than 12v going to the 12v pins with a slight risk of ground's being wrong but these are the ones that were plugged into my array the whole time (I think) and the only set of cables that had enough sata for my use (had to order a second set of cables to get all the sata I need). So all in I made an educated guess, tested it on my fan hub then put the array online and voila everything is back up. Now I can clean my PC and button it all back up. Thanks everyone for the information.
