4 hours ago, Liki04 said:
Ey my 6 fans are on the Commander pro from Corsair but i have still 3 fans can i plug the them on the Motherboard. Or what do i need to do ?
Yes you can connect those remaining fans to your motherboard.
That does mean you have to control some fan speeds in your BIOS and the other in Corsair iCUE
https://linustechtips.com/topic/1297791-commander-pro/#findComment-14420095
