15mm x 140mm fans?
JefeB
Budget (including currency): $100
Country: USA
Games, programs or workloads that it will be used for: VR
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): Does anyone know where to get 15mm x 140mm fans? I have a 280mm AIO in an ITX case and need just 1cm more to fit the GPU in. All I can find are 15 x 120. Thanks!
This will be your best bet: http://www.raijintek.com/en/products_detail.php?ProductID=5
Here is a thread of a similar nature for about 2 years ago that explains it and provides details.
"Black Out"
1tb Samsung 970 Evo | 2x 2tb Crucial MX500 SSD | Fractal Design Meshify S2 | Corsair HX1200 PSU
Dedicated Streaming Rig
 Ryzen 7 3700x | Asus B450-F Strix | 16gb Gskill Flare X 3200mhz | Corsair RM550x PSU | Asus Strix GTX1070 | 250gb 860 Evo m.2
