Corsair Vengeance Pro RGB works sometimes
So hi guys,
I have been noticing something weird about my RAM (CMW16GX4M2C32)
Sometimes the animations of the RGB work just fine sometimes they just freeze.
It even has a triangle when i hover over it, nothing happens.
The ram itself works perfectly fine.
I dont have any clue why it does this.
Thanks in advance guys!
3 hours ago, JoranC123 said:
So hi guys,
RGB on memory is controlled by separate pieces of hardware on the PCB. Thus the memory may run fine, but if there is something funky going about with RGB, that part may not function properly. My suggestion is to contact Corsair and see if they are able to assist you. Possibly file an RMA and get the kit replaced if they can't get the issue resolved.
CPU: AMD Ryzen 9 - 3900x @ 4.4GHz with a Custom Loop | MBO: ASUS Crosshair VI Extreme | RAM: 4x4GB Apacer 2666MHz overclocked to 3933MHz with OCZ Reaper HPC Heatsinks | GPU: PowerColor Red Devil 6900XT | SSDs: Intel 660P 512GB SSD and Intel 660P 1TB SSD | HDD: 2x WD Black 6TB and Seagate Backup Plus 8TB External Drive | PSU: Corsair RM1000i | Case: Cooler Master C700P Black Edition | Build Log: here
