I am rebuilding my pc and wanted to reuse the led lighting from the old build. while handling the strip I felt these dimples. The dimples appear anywhere the is an LED. Some had a crusty layer around the edges of the dimples. Seems to me like they LEDs are melting the casing. I don't remember the brand and they are powered via Sata. I had two strips daisy chained together, both strips have the same melting effect.
I do not remember if this is how they were when new. (though I doubt it) Anybody notice this on their LED strips?
Anyone out there with LED strips, it wouldn't hurt to give them a quick inspection every now and then!
https://linustechtips.com/topic/1297094-led-strip-melting/
That definitely looks like it’s melting the resin around the leds
PCPartPicker Part List: https://pcpartpicker.com/list/qJB4Xv
CPU: Intel Core i7-9700K 3.6 GHz 8-Core Processor  ($269.00 @ Amazon)
CPU Cooler: MSI MAG CORE LIQUID 240R 78.73 CFM Liquid CPU Cooler  ($109.99 @ Amazon)
Motherboard: Asus ROG STRIX Z390-E GAMING ATX LGA1151 Motherboard  ($394.98 @ Amazon)
Memory: G.Skill Trident Z RGB 32 GB (4 x 8 GB) DDR4-3000 CL15 Memory  ($174.99 @ Amazon)
Storage: Samsung 860 Evo 1 TB 2.5" Solid State Drive  ($99.99 @ Amazon)
Storage: Seagate Barracuda Compute 2 TB 3.5" 7200RPM Internal Hard Drive  ($54.99 @ Newegg)
Video Card: MSI GeForce RTX 2080 SUPER 8 GB GAMING X TRIO Video Card  ($869.99 @ Staples)
Case: Thermaltake V200 RGB ATX Mid Tower Case  ($79.98 @ Amazon)
Power Supply: Asus 850 W 80+ Platinum Certified Fully Modular ATX Power Supply  ($229.64)
Total: $2338.54
Generated by PCPartPicker 2020-12-08 10:04 EST-0500
https://linustechtips.com/topic/1297094-led-strip-melting/#findComment-14415615
Yes this can happen.  Ive read up that some companies use the lowest quality stuff and it melts.  Others dont
Workstation Laptop: Dell Precision 7540, Xeon E-2276M, 32gb DDR4, Quadro T2000 GPU, 4k display
Wifes Rig: ASRock B550m Riptide, Ryzen 5 5600X, Sapphire Nitro+ RX 6700 XT, 16gb (2x8) 3600mhz V-Color Skywalker RAM, ARESGAME AGS 850w PSU, 1tb WD Black SN750, 500gb Crucial m.2, DIYPC MA01-G case
My Rig: ASRock B450m Pro4, Ryzen 5 3600, ARESGAME River 5 CPU cooler, EVGA RTX 2060 KO, 16gb (2x8) 3600mhz TeamGroup T-Force RAM, ARESGAME AGV750w PSU, 1tb WD Black SN750 NVMe Win 10 boot drive, 3tb Hitachi 7200 RPM HDD, Fractal Design Focus G Mini custom painted.
NVIDIA GeForce RTX 2060 video card benchmark result - AMD Ryzen 5 3600,ASRock B450M Pro4 (3dmark.com)
Daughter 1 Rig: ASrock B450 Pro4, Ryzen 7 1700 @ 4.2ghz all core 1.4vCore, AMD R9 Fury X w/ Swiftech KOMODO waterblock, Custom Loop 2x240mm + 1x120mm radiators in push/pull 16gb (2x8) Patriot Viper CL14 2666mhz RAM, Corsair HX850 PSU, 250gb Samsun 960 EVO NVMe Win 10 boot drive, 500gb Samsung 840 EVO SSD, 512GB TeamGroup MP30 M.2 SATA III SSD, SuperTalent 512gb SATA III SSD, CoolerMaster HAF XM Case.
https://www.3dmark.com/3dm/37004594?
Daughter 2 Rig: ASUS B350-PRIME ATX, Ryzen 7 1700, Sapphire Nitro+ R9 Fury Tri-X, 16gb (2x8) 3200mhz V-Color Skywalker, ANTEC Earthwatts 750w PSU, MasterLiquid Lite 120 AIO cooler in Push/Pull config as rear exhaust, 250gb Samsung 850 Evo SSD, Patriot Burst 240gb SSD, Cougar MX330-X Case
https://linustechtips.com/topic/1297094-led-strip-melting/#findComment-14415618
5 minutes ago, Moonzy said:
LEDs can get very hot, to the point that they need heatsinks for larger ones
Just waiting for someone to put 200W worth of CREE LEDs inside their case!
https://linustechtips.com/topic/1297094-led-strip-melting/#findComment-14415643
hmm...i will have an psu only for my rgb dose this count?
https://linustechtips.com/topic/1297094-led-strip-melting/#findComment-14417128
