Plugged 6-pin PCE-I Into 8-pin cpu
Solved by toni2,
with a lot of luck you may just confused the bios. to be sure clear cmos and pray
but i have to agree with the others, you may fired the board or/and cpu
ShayOh ·
Posted in Troubleshooting1 -
Newbietobe5467 ·
Posted in Troubleshooting2 -
1
robjt ·
Posted in Troubleshooting13 -
6
4
Dixel ·
play_circle_filled
Latest From Linus Tech Tips:
I Will NOT Give You $250 for Your Broken Game - WAN Show April 26, 2024
play_circle_filled
Latest From ShortCircuit:
I tried 20 influencer foods, here are the best… and the worst…
