So me and my friend were playing rust and he had the idea to cheat (script) and I wasn't thinking and went along with him and tried it I ended up getting game ba, I need to know if they HWID ban they use EAC (easy anti cheat) I just really wanna play the game again.
https://linustechtips.com/topic/1296265-i-really-need-help/
12 minutes ago, Bartandroid123 said:
The only real solution that i can think of is to try to appeal to the moderators, otherwise you will have to make a new account(unless then it was an ip ban then u are ######)
HWID ban doesn't rely on IP,it relies on your specs and the ID generated for your machine.
A PC Enthusiast since 2011
AMD Ryzen 7 5700X@4.65GHz | GIGABYTE RTX 3080 GAMING OC | 4x 8GB Micron Rev.E (D9VPP) 3800MHz 16-19-14-21-58
https://linustechtips.com/topic/1296265-i-really-need-help/#findComment-14409486
"well well well, if it isn't the consequences of my own actions."
Ask the server admins for clemency. People here are not going to help you circumvent the ban you justly got for cheating.
Corps aren't your friends. "Bottleneck calculators" are BS. Only suckers buy based on brand. It's your PC, do what makes you happy.  If your build meets your needs, you don't need anyone else to "rate" it for you. And talking about being part of a "master race" is cringe. Watch this space for further truths people need to hear.
https://linustechtips.com/topic/1296265-i-really-need-help/#findComment-14409530
OP only asked if the ban is HWID ban,
After all OP didn't ask for way to circumvent it.
https://linustechtips.com/topic/1296265-i-really-need-help/#findComment-14409554
in theory hw is much worse... u need new hw...!
ip, in almost all cases you'd just need to reset your router :lol
-Scott Manley, 2021
https://linustechtips.com/topic/1296265-i-really-need-help/#findComment-14411752
