RTX 3060 Ti not keeping up with Ryzen 5 3600?
40 minutes ago, merlin95 said:do you think its strange that a ryzen 5 3600 is out matching the new 3060 ti? i know they do different things but i do understand somewhat the info shared between the cpu and gpu while gaming. 36% gpu bound means 66% is cpu or ram.
iam running the gpu on a gen 3 pci-e slot, i heard the difference between 4.0 and 3.0 isnt much but still a thought maybe?
People focus too much on the whole bottleneck thing.
The truth is it is an optimal situation to have the gpu be the bottleneck. Now if you were to run that test again at 720p then your CPU would be the bottleneck. This mostly comes down to draw calls. Your cpu has to do the calculation for the game, some potential physics, background tasks, and then on top of that do draw calls which are dependent on your fps in the game. So as frame rates go up the work is more cpu dependent, when the resolution goes up and fps decreases then the work is placed on the gpu more and it becomes the limiting factor.
The truth is no matter what you do something will always be a limiting factor. For the best case scenario in games it is best for it to be the GPU.
