A single r9 290 easily runs games at solid 60 fps in 1440p maxed out.
I only use crossfire for the latest most demanding games at ultra such as Crysis 3.
Also ignore the nVidia troll...
CPU: Intel i7 3970X @ 4.7 GHz  (custom loop)   RAM: Kingston 1866 MHz 32GB DDR3   GPU(s): 2x Gigabyte R9 290OC (custom loop)   Motherboard: Asus P9X79
Case: Fractal Design R3    Cooling loop:  360 mm + 480 mm + 1080 mm,  tripple 5D Vario pump   Storage: 500 GB + 240 GB + 120 GB SSD,  Seagate 4 TB HDD
PSU: Corsair AX860i   Display(s): Asus PB278Q,  Asus VE247H   Input: QPad 5K,  Logitech G710+    Sound: uDAC3 + Philips Fidelio x2
HWBot: http://hwbot.org/user/tame/
https://linustechtips.com/topic/129554-help-guys/page/2/#findComment-1724441
I'm sorry, but a GTX titan SLI with 3 way 4k surround won't lag at all. Yes it does make it smoother and that's it's whole purpose. Mantle does more than that, I tested it with a R7-250 and a a8-5600k and it boosted my FPS even at 1080p. It does help for people gaming at low resolution too.
mantle is the way to go if you are on a budget
but i doubt mantle will be a thing in 2015 with dx12 around from what i heard
will i said what i have to say
OP for you i recommend a 1080p 144hz monitor
that is all :)
i hope no one got offended by my comments lol
Real programmers don't document, if it was hard to write, it should be hard to understand.
I've learned that something constructive comes from every defeat.
https://linustechtips.com/topic/129554-help-guys/page/2/#findComment-1724450
lol sure
have fun op at tearing :D
-snip-
Tearing is usually that bad at low framerates.
@OP, take it from someone with experience with monitors. Go for 1440p and have the time of your life with gaming. You won't get tearing most of the time.
https://linustechtips.com/topic/129554-help-guys/page/2/#findComment-1724453
you are fine
1440p is too hard for amd cards from exerience
even if you went with amd for 1440p you will lag and tearing and juggering unlike Nvidia
Nvidia is the way to go
so don't bother
no just no
too hard ... are you kidding me
im running a 1600p monitor on my GTX 570 at 1.2GB Vram lol ......
buy a 290 it will be fine
If your grave doesn't say "rest in peace" on it You are automatically drafted into the skeleton war.
https://linustechtips.com/topic/129554-help-guys/page/2/#findComment-1724456
just to add support for this, I have never had tearing @1440 with my 780 ti (since there is no difference between AMD and Nvidia with out G SYNC)
Corsair 400C- Intel i7 6700- Gigabyte Gaming 6- GTX 1080 Founders Ed. - Intel 530 120GB + 2xWD 1TB + Adata 610 256GB- 16GB 2400MHz G.Skill- Evga G2 650 PSU- Corsair H110- ASUS PB278Q- Dell u2412m- Logitech G710+ - Logitech g700 - Sennheiser PC350 SE/598se
Is it just me or is Grammar slowly becoming extinct on LTT?
https://linustechtips.com/topic/129554-help-guys/page/2/#findComment-1724459
that is all :)
Just stop you fanboy, no need for you to contribute when you make no sense
PC: Corsair C70 Arctic, FX 9370, Corsair H80i, Gigabyte 990fxa-ud3, Corsair Vengence 16gb, Palit JetStream GTX 970, OCZ Vertex 4 128gb and Western Digital Blue 1Tb + 500gb, Antec Gamer 520w
Peripherals: Logitech G19 and SteelSeries Sensei RAW
Toshiba L50-A: i7 4700mq, 8gb, 1TB HDD, GT 740M 2gb
https://linustechtips.com/topic/129554-help-guys/page/2/#findComment-1724481
that is all :)
STHAP!
YOU'RE FANBOYING TOO HARD
-The Bellerophon- Obsidian 550D-i5-3570k@4.5Ghz -Asus Sabertooth Z77-16GB Corsair Dominator Platinum 1866Mhz-x2 EVGA GTX 760 Dual FTW 4GB-Creative Sound Blaster XF-i Titanium-OCZ Vertex Plus 120GB-Seagate Barracuda 2TB- https://linustechtips.com/main/topic/60154-the-not-really-a-build-log-build-log/ Twofold http://linustechtips.com/main/topic/121043-twofold-a-dual-itx-system/ How great is EVGA? http://linustechtips.com/main/topic/110662-evga-how-great-are-they/#entry1478299
https://linustechtips.com/topic/129554-help-guys/page/2/#findComment-1725292
lol sure
Nvidia cards will have tearing too. G-Sync isn't even out yet and won't be for a while, and when it does, it will cost a METRIC ASS TON.
Now stop qqing about how Nvidia is supposedly better than AMD.
I have owned an HD 7970, R9 280X and a GTX 780, non of which have had any issues. Mantle is nothing but good due to the fact that it is free, and it boosted my fps by 10-20fps @1080p. I have never had tearing on any of the 3 cards.
The R9 290 will probably perform similarly to the 780 @1440p, maybe even better. Stop fanboying so hard. I don't see why you can't understand that both are GREAT companies.
https://linustechtips.com/topic/129554-help-guys/page/2/#findComment-1726092
Guys i have a r9 290 but i only have 15inches 1366 x 768. With that display will my 290 can use its full performance?
ahahha lol really funny! lol thats like 720p lol a 7770 can max out on that resolution lol. so 290 damn straigt. Id day upgrade that crappy monitor to at least 1080 p monitor and ull be running max setting depending to game to game plus cpu does affect your over all fps. and for the love of god i hope you dont have crappy cpu. that 15 inch monitor creeps me out makes me give me the chills cause ya system sounds cheap!!
Edit looked at ya profile. Ya got a good cpu!
Amd fx-8320 oc 4.1ghz, 8gb ram, gtx 780ti 3gb, 240gb ssd, 1.5tb hdd,
https://linustechtips.com/topic/129554-help-guys/page/2/#findComment-1728995
