Yes.
MSI does not have an ownership clause in their warranty information, which you can find at https://us.msi.com/page/warranty. They will only ask for the product's serial number to submit an RMA.
Make sure to quote me or use @PorkishPig to notify me that you replied!
Desktop
CPU - Ryzen 9 3900X | Cooler - Noctua NH-D15 | Motherboard - ASUS TUF X570-PLUS RAM - Corsair Vengeance LPX DDR4-3200 32GB Case - Meshify C
GPU - RTX 3080 FE PSU - Straight Power 11 850W Platinum Storage - 980 PRO 1TB, 960 EVO 500GB, S31 1TB, MX500 500GB | OS - Windows 11 Pro
Homelab
CPU - Core i5-11400 | Cooler - Noctua NH-U12S | Motherboard - ASRock Z590M-ITX RAM - G.Skill Ripjaws V DDR4-3600 32GB (2x16)  | Case - Node 304
PSU - EVGA B3 650W | Storage - 860 EVO 256GB, Sabrent Rocket 4.0 1TB, WD Red 4TB (x6 in RAIDZ1 w/ LSI 9207-8i) | OS - TrueNAS Scale (Debian)
https://linustechtips.com/topic/1295420-rtx-3080-help/#findComment-14402999
6 minutes ago, PorkishPig said:
Yes.
so if i buy it off him i can rma if theres an issue right?
https://linustechtips.com/topic/1295420-rtx-3080-help/#findComment-14403016
Try and get the receipt off them, too... if only to verify the date of purchase (for future warranty purposes).  Dunno if registering a card w/ the manufacturer limits the warranty, but if what@PorkishPigsaid is right, it shouldn't.
**I frequently edit any posts you may quote; please check for anything I 'may' have amended.**
Current PC spec. in my profile.
Can I realistically call myself a gamer, if I only play ONE, twenty year old game...?
Did you test boot it, before you built in into the case?
WHY NOT...?!
https://linustechtips.com/topic/1295420-rtx-3080-help/#findComment-14403026
Just now, Eighjan said:
Try and get the receipt off them, too... if only to verify the date of purchase (for future warranty purposes).  Dunno if registering a card w/ the manufacxturer limits the warranty, but if what @PorkishPigsaid is right, it shouldn't.
ok and how does rma work i can send it to them and they send me a replacement or do they fix it?
https://linustechtips.com/topic/1295420-rtx-3080-help/#findComment-14403031
and sorry im asking alot ive just never shipped something or sent something back before
https://linustechtips.com/topic/1295420-rtx-3080-help/#findComment-14403045
Usually you 'trigger' an RMA through the manufacturer's support section of their website.
Whether they fix or replace is up to them... best to be prepared for either.
Edited by Eighjan
WHY NOT...?!
https://linustechtips.com/topic/1295420-rtx-3080-help/#findComment-14403048
Just now, Ghostly224 said:
how long does it usually take?
Usually based on where you have to send it... work on them having to verify the fault first & transport both ways; a minimum of 2 weeks wouldn't be unfair.
WHY NOT...?!
https://linustechtips.com/topic/1295420-rtx-3080-help/#findComment-14403064
RMA with the 3080 will take very long.....
They will offer to refund you there is no stock.
Also many manufacturers will try to force you to go through the seller.
Get the recite/invoice get the original packaging. If he cant provide those I would stay away.
Also are you in the EU? Laws differ region to region. And where was the GPU bought.
https://linustechtips.com/topic/1295420-rtx-3080-help/#findComment-14403168
2 hours ago, PorkishPig said:
Yes.
Pretty sure you need a receipt too, if only to prove the date of purchase - but also otherwise with an expensive card like this they can and probably *will* flat out deny any free RMA services or the like.
-Scott Manley, 2021
https://linustechtips.com/topic/1295420-rtx-3080-help/#findComment-14403375
Based on what I've collected from Reddit threads (this one for example), they seem to allow warranty claims with just the serial number. You're right, however, there is absolutely no guarantee of an RMA being approved.
Desktop
Homelab
https://linustechtips.com/topic/1295420-rtx-3080-help/#findComment-14403402
