I'm building a PC for a small gaming YouTuber and I want your help on picking out the parts!
Will be used for: Recording(obvs.) video editing(obvs.) and uploading YouTube videos.... kind of a given but people still ask that stuff....
Requirements:
2GB VRAM
Shadowplay
8GB RAM 1600MHz+
Use Amazon and/or Newegg
NEED OS
As the title says, it needs to be less than $600 USD.
No peripherals needed.
https://linustechtips.com/topic/129496-600-pc-build-help/
Is a copy of Windows or any peripherals needed? It's for gaming, right?
https://linustechtips.com/topic/129496-600-pc-build-help/#findComment-1723331
Updated.
have them use trial indefinitely, all they miss out on is updates (lel), wallpaper, aero, and other windows downloadable crap. Not missing much.
they can buy the OS later when they rake in some money. OS now cuts into performance forever, OS later cuts into performance (conveniences really) temporarily now.
Error: 410
https://linustechtips.com/topic/129496-600-pc-build-help/#findComment-1723352
PCPartPicker part list: http://pcpartpicker.com/p/3cYxO
Price breakdown by merchant: http://pcpartpicker.com/p/3cYxO/by_merchant/
Benchmarks: http://pcpartpicker.com/p/3cYxO/benchmarks/
CPU: AMD Athlon X4 750K 3.4GHz Quad-Core Processor  ($79.99 @ Amazon)
Motherboard: MSI FM2-A75MA-E35 Micro ATX FM2 Motherboard  ($89.99 @ Amazon)
Memory: G.Skill Ares Series 8GB (2 x 4GB) DDR3-1600 Memory  ($64.99 @ Newegg)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($59.24 @ Amazon)
Video Card: PNY GeForce GTX 760 2GB Video Card  ($236.99 @ Amazon)
Case: NZXT Source 210 (Black) ATX Mid Tower Case  ($50.98 @ Newegg)
Power Supply: Corsair Builder 430W 80+ Bronze Certified ATX Power Supply  ($44.99 @ Newegg)
Total: $627.17
(Prices include shipping, taxes, and discounts when available.)
(Generated by PCPartPicker 2014-03-19 22:34 EDT-0400)
https://linustechtips.com/topic/129496-600-pc-build-help/#findComment-1723357
Or Linux, there's always Linux. Not many games.... but it's still there. Would prefer Windows though.
https://linustechtips.com/topic/129496-600-pc-build-help/#findComment-1723362
Did you even read the OP? :P
Oh, my mistake--been awake for 30+ hours or so.
@WoodenMarker
Updated.
How's this look? http://pcpartpicker.com/p/3cYzW
https://linustechtips.com/topic/129496-600-pc-build-help/#findComment-1723369
My take  Edit:(oops! forgot ShadowPlay) :
PCPartPicker part list / Price breakdown by merchant / Benchmarks
CPU:  AMD FX-6300 3.5GHz 6-Core Processor  ($109.99 @ Amazon)
Motherboard:  Gigabyte GA-78LMT-USB3 Micro ATX AM3+ Motherboard  ($58.29 @ Newegg)
Memory:  A-Data XPG V1.0 8GB (2 x 4GB) DDR3-1600 Memory  ($61.99 @ Newegg)
Storage:  Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($59.99 @ Newegg)
Video Card:  EVGA GeForce GTX 750 Ti 2GB Video Card  ($149.99 @ NCIX US)
Case:  Antec One ATX Mid Tower Case  ($34.99 @ Newegg)
Power Supply:  Corsair Builder 430W 80+ Bronze Certified ATX Power Supply  ($24.99 @ Newegg)
Operating System:  Microsoft Windows 8.1 - 64-bit (OEM) (64-bit)  ($135.98 @ Newegg)
Total: $636.21
(Generated by PCPartPicker 2014-03-19 22:48 EDT-0400)
https://linustechtips.com/topic/129496-600-pc-build-help/#findComment-1723406
http://pcpartpicker.com/user/Really2n2/saved/46NN What I'll go with, I would go with the 750 ti but you need a OS so had to downgrade a little. (this build is basically what Linus did in his budget computer build)
The time you enjoy wasting, is not wasted time.
https://linustechtips.com/topic/129496-600-pc-build-help/#findComment-1723478
Yes, i recommend just going with that build but with a 750 or a 750 ti
Christian and Proud of it
Please read the CoC        My Build Log
https://linustechtips.com/topic/129496-600-pc-build-help/#findComment-1723541
The OP specifically said that he wanted to have Shadowplay compatibility. Just incase you don't know what that is, it is a livestreaming/game recording software only supported by nVidia GPU's. He would be forced to go with a 750ti or something of the sorts in order to take advantage of its features.
However, I would recommend this build from @WoodenMarker
//ccap
https://linustechtips.com/topic/129496-600-pc-build-help/#findComment-1723569
Ah, thanks matey... I forgot the keep that in mind.... then in that case I'll throw in a 750 to correct myself
https://linustechtips.com/topic/129496-600-pc-build-help/#findComment-1723596
Almost $700, though...
CPU:  AMD Athlon X4 760K 3.8GHz Quad-Core Processor  ($84.74 @ Amazon)
Motherboard:  MSI A88XM-E35 Micro ATX FM2+ Motherboard  ($59.99 @ Newegg)
Video Card:  EVGA GeForce GTX 760 2GB Video Card  ($249.99 @ Newegg)
Case:  Xigmatek Recon ATX Mid Tower Case  ($29.99 @ Newegg)
Power Supply:  Corsair Builder 600W 80+ Bronze Certified ATX Power Supply  ($37.99 @ Newegg)
Operating System:  Microsoft Windows 8.1 (OEM) (64-bit)  ($101.98 @ Newegg)
Total: $683.93
(Generated by PCPartPicker 2014-03-19 23:23 EDT-0400)
The 760K was about $5 more than the 750K. The 600W PSU might be excessive, but it might be worth it to keep for future upgrades, but if not, then go for the Corsair 430W one or something less expensive. That's pretty much it, I just wanted to see if I could include a GTX 760 around your price point. If it's too expensive for your tastes, then go for the GTX 750 Ti and that'll drop the almost $700 to probably $650 or so. Also, you could go for a less expensive GTX 760, like the MSI one.
Here's the build with a GTX 750 Ti, lower PSU, and an optical drive because why not?
Video Card:  MSI GeForce GTX 750 Ti 2GB Video Card  ($164.99 @ Amazon)
Optical Drive:  Samsung SH-224DB/BEBE DVD/CD Writer  ($14.99 @ Newegg)
Total: $600.92
(Generated by PCPartPicker 2014-03-19 23:32 EDT-0400)
| CPU: An abacus | Motherboard: Tin foil | RAM: 2 Popsicle sticks | GPU: Virtual Boy | Case: Cardboard box | Storage: Cardboard | PSU: 3... Er... Make that 2 hamsters | Display(s): Broken glass | Cooling: Brawndo | Keyboard: More cardboard | Mouse: Jerry | Sound: 2 Cans of SpaghettiO's |
https://linustechtips.com/topic/129496-600-pc-build-help/#findComment-1723636
PCPartPicker part list: http://pcpartpicker.com/p/3d16Z
Price breakdown by merchant: http://pcpartpicker.com/p/3d16Z/by_merchant/
Motherboard: MSI 970A-G43 ATX AM3+ Motherboard  ($59.99 @ Micro Center)
Memory: A-Data XPG V1.0 8GB (2 x 4GB) DDR3-1600 Memory  ($63.99 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($57.98 @ OutletPC)
Video Card: Asus GeForce GTX 750 Ti 2GB Video Card  ($159.99 @ NCIX US)
Power Supply: Corsair Builder 430W 80+ Bronze Certified ATX Power Supply  ($19.99 @ Micro Center)
Operating System: Microsoft Windows 8 (OEM) (64-bit)  ($97.98 @ OutletPC)
Total: $604.90
(Generated by PCPartPicker 2014-03-20 00:06 EDT-0400)
https://linustechtips.com/topic/129496-600-pc-build-help/#findComment-1723802
