Corsair Commander PRO & X570 | USB 2.0 hub incompatible issues
kyookyoo
I was anyone has found a solution to my current issue. I can't find anything besides purchasing a internal USB 2.0 hub/splitter.
CPU: 5900X
Cooler: Corsair H150i
MOBO: Asus ROG STRIX X570 I-Gaming
Controllers: Commander Core & Commander PRO
Fans: x3 HD120 RGB, x3 ML120 RGB, x2 HD140 RGB
My mobo only has x1 USB 2.0 header, so I initially plugged in my Commander PRO into the mobo, then plugged in the Commander Core from the H150i into the USB hub on the PRO. But when I do this and check Device Manager (GENERIC USB HUB [yellow triangle]) & iCue doesn't show up. I tried uninstalled drivers and reinstalled from device manager, updated my firmware (Commander PRO) & software (iCue), I did a hard reset on the Commander PRO and uninstalled and reinstalled iCue based on Corsair Support email i attached. Idk at this point. From basic googling, it seems like it's an X570 issue, but some users have told me they never ran into this issue using a similar setup.
I ordered a NZXT internal USB 2.0 header as a workaround for now, but I was wondering if there is a fix so I dont have to rely on that.
Any help would be greatly appreciated.
CPU: 5900X
like 99% of mb have latest 2 usb 2.0 headers... ill take a look but i dont think you no what your looking for. also can you just plug in the core dose that show up?
Corsair Lian Li Bykski Barrow thermaltake nzxt aquacomputer 5v argb pin out guide + argb info
5v device to 12v mb header
Odds and Sods Argb Rgb Links
CPU: 5900X
oh you have an micro atx mb...
so you have 2 set of usb 2.0 and and usb 3.2. the usb 2.0 has 2 in it. and the usb 3.2 should be backward compatible with usb 2.0 with an adapter.  you can buy a splitor for the usb 2.0 but i dont no if the core or commander need both to work. im guessing the commander dose for the hub but i would think the core should work with just one.
 seems like a shit tone of fans for an micro atx...but w/e
Edited by thrasher_565
I definitely agree with your solution, I was just wondering if there was a corsair solution itself. I already ordered a usb 2.0 hub that works, just annoying that I had to buy an extra component cuz Corsair didnt make their products compatible for 3yrs +
ya i dont no why it didn't work some one will no why thow. i guess its kinda free in the commander but still.
Appreciate you feedback though, thanks @thrasher_565. 🙂
