Contour have a screenshot perhaps?
Do you mean their open test benches?
https://linustechtips.com/topic/1294151-ltt-benchmark-pc-case/#findComment-14393763
I'm pretty sure they use open test benches for most of the tests. Only when you see full build, or something where components being inside the case would have importance they are in the case. They tend to use be Quiet! cases due multiple sponsorships.
Linus has talked about their testing methods in WAN Shows. The short of it is that they focus on things where the environment shouldn't play major role. Jayz2cents does he's benchmarking on test bench, OC3D uses some Corsair case from couple years ago. The main thing being that system should go through as few changes as possible to keep data comparison valid.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/1294151-ltt-benchmark-pc-case/#findComment-14393920
16 hours ago, CajuCLC said:
This is what I am looking for:
This is the most recent video about the subject. The description has links to stuff they use.
https://linustechtips.com/topic/1294151-ltt-benchmark-pc-case/#findComment-14396971
The test benches LTT use are from https://openbenchtable.com/
I don't think they've used a be quiet case or been sponsored by them for quite a while. If I recall their last Be Quiet video was the $1000 build guide, back in 2017.
https://linustechtips.com/topic/1294151-ltt-benchmark-pc-case/#findComment-14396979
Looking at the past few videos featuring full build where the point is not the case and its not sponsored:
  • RTX 3090 SLI - We Tried so Hard to Love It: Lian-Li O11 Dynamic Razer Edition
  • AMD vs. Intel midrange gaming PC challenge: Corsair 275R (video was sponsored by Corsairs keyboards)
  • How to build a PC without getting RIPPED OFF!: Rosewill FBM-X2, Phanteks Eclipse P300A
  • The Fastest Gaming PC in the World! ...For now: Phanteks P600
So I was wrong about be Quiet! being preference. Though I have vague memory of seeing much of those in videos after the sponsorship. Overall, good for LTT showing off multiple cases for the builds.
https://linustechtips.com/topic/1294151-ltt-benchmark-pc-case/#findComment-14396988
It is a Streacom.
RIG#1 CPU: AMD, R 7 5800x3D| Motherboard: X570 AORUS Master | RAM: Corsair Vengeance RGB Pro 32GB DDR4 3200 | GPU: EVGA FTW3 ULTRA  RTX 3090 ti | PSU: EVGA 1000 G+ | Case: Lian Li O11 Dynamic | Cooler: EK 360mm AIO | SSD#1: Corsair MP600 1TB | SSD#2: Crucial MX500 2.5" 2TB | Monitor: ASUS ROG Swift PG42UQ
RIG#2 CPU: Intel i9 11900k | Motherboard: Z590 AORUS Master | RAM: Corsair Vengeance RGB Pro 32GB DDR4 3600 | GPU: EVGA FTW3 ULTRA  RTX 3090 ti | PSU: EVGA 1300 G+ | Case: Lian Li O11 Dynamic EVO | Cooler: Noctua NH-D15 | SSD#1: SSD#1: Corsair MP600 1TB | SSD#2: Crucial MX300 2.5" 1TB | Monitor: LG 55" 4k C1 OLED TV
RIG#3 CPU: Intel i9 10900kf | Motherboard: Z490 AORUS Master | RAM: Corsair Vengeance RGB Pro 32GB DDR4 4000 | GPU: MSI Gaming X Trio 3090 | PSU: EVGA 1000 G+ | Case: Lian Li O11 Dynamic | Cooler: EK 360mm AIO | SSD#1: Crucial P1 1TB | SSD#2: Crucial MX500 2.5" 1TB | Monitor: LG 55" 4k B9 OLED TV
RIG#4 CPU: Intel i9 13900k | Motherboard: AORUS Z790 Master | RAM: Corsair Dominator RGB 32GB DDR5 6200 | GPU: Zotac Amp Extreme 4090  | PSU: EVGA 1000 G+ | Case: Streacom BC1.1S | Cooler: EK 360mm AIO | SSD: Corsair MP600 1TB  | SSD#2: Crucial MX500 2.5" 1TB | Monitor: LG 55" 4k B9 OLED TV
https://linustechtips.com/topic/1294151-ltt-benchmark-pc-case/#findComment-14396998
If you want to order one go through Newegg. They are cheaper than the openbenchtable website.
https://linustechtips.com/topic/1294151-ltt-benchmark-pc-case/#findComment-14397040
