Best case for GPu thermals
19 hours ago, JakebR said:Last month after a lot of F5 I managed to buy my 5600x + 3080 Trio X + XPG 750W PSU.
Now I need to upgrade my case + CPU fan and I already bought the CPU fan (Fuma 2).
There is only one thing that I need help choosing, the case and here are my options:
Lian Li Lancool 215 $ 125
Corsair 4000D Airflow $150
Cooler Master TD500 $150
Lian Li Lancool II Mesh RGB ( the performance is out of stock) $ 150
Which one would give me better thermal results ? Specially for my GPU.
Please don't recommend Phanteks/Be quiet!/Fractal/SilverStone cases since its impossible to find them in my country.
I was curious what country you lived in because of the price hike.
If you are going to leave the GPU inserted in the motherboard, then I would recommend the Lancool II Mesh. Sorry that they don't have the Performance one for you.
To better get cooling on your GPU, pick up a 3x120MM fans and one 140MM fan. Mount 2 of them on top of the PSU shroud. There is opening for them, they get their air from the side bottom cover.
And install one on the rear exhaust and for air balance install another exhaust on the top rear location (140MM). The RGB model has 3X 120MM RGB fans in the front of the case and no rear exhaust fan.
I hope this helps.
If you would rather save money, you could build in the Lancool 215. I just did that to make my son's PC MUCH lighter for taking back and forth to college. I know there are openings on the PSU Shroud, I just didn't see if they were removable.
