1 minute ago, Haven_Alpha said:
blowing on mechanical switches
Kinky, have to add this to my next photoshoot. 🤪
2 minutes ago, Haven_Alpha said:
How does this work can someone explain??
My guess is it removes the dust that was interfering with things.
NOTE: I no longer frequent this site. If you really need help, PM/DM me and my e.mail will alert me.
https://linustechtips.com/topic/1291370-blowing-on-switches/#findComment-14374117
Agreed, likely blowing dust or something off the contacts, although in my experience if a board is dirty enough for dust to stop the contacts from making electrical contact, there are many other problems with the board...
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
https://linustechtips.com/topic/1291370-blowing-on-switches/#findComment-14374160
Sometimes, adding a little 90-100% isopropyl alcohol inside works wonders too, but most of the time, if the switch is malfunctioning, it means that its time has come.
All switches have not only physical lifespan, but also electrical lifespan, and if it's the latter, there's no fix to that other than to replace the switch altogether.
https://linustechtips.com/topic/1291370-blowing-on-switches/#findComment-14374183
