I know this isn't a audiphile forum but I was hoping somebody could help me out with a turntable. I am looking for under $200 as an intro one. I dont have any speakers, amps or anything. It needs to play all three speeds......
Any help would be great!!
| 3570k @ 4.5 | swiftech h220 ordered after patent issues | EVGA 660ti SC 3gb | 8gb gskill ripjaws | Asus p8z77-v lx | Corsair Ax 750 | Asus Xonar DS | Corsair C70 white | CM quickfire rapid mx browns | G500 |
https://linustechtips.com/topic/129014-turntable-help/
A Rega Planar 3 is one of the best in the entry level bracket and is generally a very convincing turntable. It's super stable and with a good pickup you will have absolutely no reason to upgrade it before you've got 5+ grand to spend on one of the high end offerings. On a good day you should be able to find a used one for a couple hundred bucks.
https://linustechtips.com/topic/129014-turntable-help/#findComment-1716716
Do you need speakers and amps and such, or just the turntable?
https://linustechtips.com/topic/129014-turntable-help/#findComment-1717414
what country, I probably start looking at denon, marantz etc, they have starting products around that price. or alternatively you can look in second habd shops or on ebay, just prepare to get a new stylus cartridge if you by second hand.
Grammar and spelling is not indicative of intelligence/knowledge.  Not having the same opinion does not always mean lack of understanding.
https://linustechtips.com/topic/129014-turntable-help/#findComment-1717522
Used dollar sign, implying US.
He is going to be forced to buy all three items used.
https://linustechtips.com/topic/129014-turntable-help/#findComment-1717576
we have dollars and the euro is a dollar too.  But I agree, getting  something decent for that price is going to be secondhand regardless of his currency.
https://linustechtips.com/topic/129014-turntable-help/#findComment-1717601
Sorry to offend lol.....
The reason is i have always wanted to listen to vinyl and recently was given a bunch of them recently so i figured it's time to make the leap. So buying used is perfectly fine is what everyone seemes to be getting at????
https://linustechtips.com/topic/129014-turntable-help/#findComment-1717616
actually buying used is probably the better way to go, with exception of maybe having to buy a new cartridge.  I am currently using an akai unit which I have had for about 15 years at least and I am quite happy with it.
https://linustechtips.com/topic/129014-turntable-help/#findComment-1717720
