How to setup "Sign Into Wifi Network" option on my router?
Solved by SupaKomputa,
You need a router with Captive Portal function which is not supported in your router.
I suggest just using a password.
Featured Topics
2
4
18
2
JFRStudent ·
Posted in Photography and Videography1
play_circle_filled
Latest From Linus Tech Tips:
I Am Not Buying A Super Computer - WAN Show May 3, 2024
