Wire help
Go to solution Solved by minibois,
1 minute ago, MayoKat said:
It is a NZXT case
You need this connector (which says F_PANEL next to it):
One pin is blocked off on the connector, so you can only plug it in one way.
Just now, MayoKat said:
Which one of these does this go into?
Before I say which connector for sure. Is this an NZXT case?
https://linustechtips.com/topic/1287492-wire-help/#findComment-14344604
It is a NZXT case
https://linustechtips.com/topic/1287492-wire-help/#findComment-14344659
