Just now, aidan22cheese said:
Whats are some disadvantages of getting a micro atx motherboard compared to getting an ATX motherboard. Im debating on which one i should get since micro atx motherboards are cheaper.
The difference comes down to a board vs. board level. Not all ATX or mATX boards are the same.
Generally though, mATX boards have fewer PCIE slots, could have fewer M.2 slots (but that doesn't have to be the case) and mATX boards are just smaller.
If you're getting an ATX case, an mATX motherboard could look silly, but unless you really need those last PCIE slots, I think mATX is the motherboard size that makes the most sense for most people.
https://linustechtips.com/topic/1287292-micro-atx-vs-atx/#findComment-14343295
oh that makes sense. Isnt there better airflow and more compatability in an atx case though?
https://linustechtips.com/topic/1287292-micro-atx-vs-atx/#findComment-14343304
Typically cheaper = lower quality VRMs, and less features and expansion slots, this has little to do with overall form factor though. You can get micro ATX boards with good VRMs as well.
AMD Motherboard Tier List  GPU Cooling Tier List  PSU Tier List  A Dive Into Custom Keyboards & Mechanical Switches
NEWCOMERS Remember to ' Reply ' to comments in order for people to see them, this is done by clicking the arrow icon at the bottom of a comment (Quote).
My Builds:
MEGA Desk Build
Blueberry Pi  R9 3950X  Asus X470 ROG Crosshair VII Hero Wi-Fi ATX  Corsair Vengeance RGB Pro 4x16GB 3200MHz CL16  EVGA GTX 1080Ti SC Black Edition 11GB  EVGA P2 850W w/ Blue Sleeved Cables  Cryorig R1 Universal (Blue)  2x Corsair Force MP510 4TB w/ Asus Hyper m.2 V2  Corsair ML Pro Blue LED Fans  Fractal Design Meshify C TG ATX Mid Tower
Asus ROG SWIFT PG348Q 100Hz IPS G-Sync UW  Dell UltraSharp U3419W 60Hz IPS UW  Custom TOFU96  Corsair Scimitar Pro RGB
Work Rig  ThreadRipper 3970X  Asus Prime TRX40 Pro ATX  G.Skill RipjawsV 8x32GB 3200Mhz CL16  Nvidia Quadro RTX 6000 24GB  Corsair HXi 1000W  EVGA CLC 360 AIO  8x Sabrent Rocket 2TB w/ 2x Asus Hyper m.2 V2   Arctic P12 Fans  Phanteks P400A ATX Mid Tower
Plotting Machine 1  ThreadRipper 2990WX  AsRock X399 Taichi ATX  Kingston HyperX Fury 8x16GB 2666Mhz CL18   Nvidia Quadro K600 1GB  Corsair RMx 850W  EVGA CLC 360 AIO ‖ 2x Sabrent Rocket 2TB & 2x Sabrent Rocket 4TB w/ Asus Hyper m.2 V2  Arctic P12 Fans  Rosewill RSV-L4500 4U  5x Dell DS60 60-bay JBOD w/ 1.2PB of HDD Storage  HP 22U Half Rack
Plotting Machine 2  R9 3950X  Asus TUF X570-Plus Wi-Fi ATX  G.Skill RipjawsV 4x16GB 3200Mhz CL16   Nvidia Quadro K600 1GB  Corsair RM 650W  Noctua NH-D15s Chormax ‖ 4x Corsair MP600 Force 1TB W/ Asus Hyper m.2 Gen4  Arctic P14 & P12 Fans  Silverstone FARA R1 ATX Mid Tower
J.A.R.V.I.S.  R9 3900XT  Asus B550-I ROG STRIX Wi-Fi ITX  G.Skill Ripjaws V 2x16GB 3600MHz CL16  EVGA GTX 1080 SC2 iCX 8GB  Corsair SF 750W Platinum  Corsair H100i Pro AIO  Noctua NF-A12x15 Chromax Fans  FormD T1 SFF ITX Case
LG 75UM8070PUA 4K UHD 120Hz IPS HDR TV  Corsair K63 Cherry MX Red Special Edition Wireless  Corsair Ironclaw RGB Wireless
Archive Server  R3 2200G  Asus B450-I ROG STRIX Wi-Fi ITX  Corsair Vengeance RGB Pro 2x8GB 3200MHz CL16 White  Vega Integrated Graphics  EVGA P2 750W  Prism Wraith Cooler  ITX Open Bench  2x HP SAS Expander  LSI-SAS9211  220TB of HDD Storage
SFF ITX Home PC  i5-7500  MSI B250I Gaming Pro Wi-Fi AC ITX  G.Skill Ripjaws V 2x8GB 2800MHz  Intel Integrated Graphics  Seasonic SSP Flex ATX 300W PSU  Cryorig C7  Velka 3 rev 1.2 SFF ITX Case (Grey)
Laptop  Dell XPS13 2-in-1 7390 (2020)  i7-1065G7  32GB 3733MHz LPDDR4x  Intel Integrated Graphics  1TB NVME M.2  UHD+ (3840 x 2400) InfinityEdge Touch Display
Keyboard Collection  GMMK Full Size  TOFU96 90%  ‖ KBD8x MKII TKL ‖ Drop CTRL High Profile TKL ‖ KBD Bella 75% ‖ GMMK Pro 75% ‖ XD84 Pro 75%  KBD67 V2 MKII 65%  KBD67Lite 65%  TOFU65 65%  KBD Blade 60%  Drop Carina 60%  Southpaw75 60% w/ Left Numpad  OLKB Preonic V3 Ortholinear ‖ CosPad XD24  ‖ KBDPad MKII
Key Cap Collection  GMK Boba Fett  GMK Red Samurai  GMK Laser CyberDeck +Novalties  GMK Arch  MaxKey B&W  Drop MT3 Camillo ‖ Matt3o MT3 /dev/tty  KBDfans Biip Torii Ext-2048  ePBT Less But Better +Novalties  EnjoyPBT Dolch  WinMix Mustard  Drop Skylight Horizon & Slate ‖ Glorious Black Aura
Mechanical Key Switch Collection  Zealios V2 65g  Zealios V2 78g ‖ Zilents V2 67g  Tealios V2 67g  C³ Kiwi ‖ C³ Tangerine  Invyr Holy Panda  Durock T1 67g  Kailh Box Thick Jades ‖ Kailh Box Royal ‖ Kailh Box Heavy Dark Yellow ‖ Kailh Box Heavy Burnt Orange  Kailh Box White  Kailh Box Red  Kailh Pro Purple  Kailh Pro Burgandy  Gateron Ink Black V2  Gateron Black  Gateron Yellow  Gateron Brown  Gateron Green  Gateron Blue ‖ Cherry MX Black ‖ Cherry MX Brown ‖ Cherry MX Red
https://linustechtips.com/topic/1287292-micro-atx-vs-atx/#findComment-14343316
Better airflow depends on the case.
There are ATX cases with good and bad airflow and so is the case with mATX cases. ATX motherboards are only 6cm taller than mATX cases, which means it's half the height of another 120mm fan, so it's not like just by having an ATX case you will always be able to add a fan extra.
Compatibility is debatable too.
Space for two 3.5" drives and two 2.5" drives is basically standard, in mATX and ATX.
Room for a large videocard doesn't differ between mATX and ATX either. Same for room for a large PSU.
Not sure what 'Compatibility' you could otherwise be referring to.
https://linustechtips.com/topic/1287292-micro-atx-vs-atx/#findComment-14343319
Most differences comes down to case airflow and case expansion.
For motherboards there are often fewer electrical limits on matx versions. Why? Well other than the first 16x slot and the first m.2 (on amd since 1000 series and on Intel with 11000 series).
All other pcie ports and m.2 share lanes, most often a 4x pcie 3.0 pipe from the CPU with only x570 double that with 4x 4.0 pipe that can then be split into lanes
But for the most parts they only gives 8 lanes of gen 2.0 (b450) or 3.0 (b550) of maximum bandwidth. So choosing say a Asus b550 ATX board most of the ports are disabled anyway since they only allow for one or two ways of expansion at a time due to the limited lanes. Matx have less ports and so less need to limit what is possible on the rest of the ones.
On the Asus b550 tuf gaming wifi the only limit with lanes is that the bottom 4x is only used at 2x if any of the 1x ports are used, so no 4k60 capture card
But on the b550 tuf it have more 1x ports but same thing there the 4x port limits to 1x lane If any other 1x is populated.
The ATX does it a bit differently the 4x and 1x share lanes so as Long as not all 1x and 4x ports is loaded at a time it will be fine. Intel also mostly does it that way too.
But different manufactures priorities differently, MSI disable the second m.2 on b550 if a card is placed in the 4x port to always have the 1x ports available, and Asus you choose 1x or 4x expansion but with second m.2 always being active.
But in he end all hat data must go through a 4x 3.0 pipe to the CPU so even though chipset might provide 8 lanes of 3.0 maximum, it is not possible to load more than the 4x bandwidth.
And that is why x570, threadripper and x299 exist, more bandwidth from cpu to chipset or in the latter two, more lanes directly from CPUs
https://linustechtips.com/topic/1287292-micro-atx-vs-atx/#findComment-14344491
