Arctic P12 PWM or Scythe Kaze Flex PWM
bunkerverein
I'm planning to get some new case fans and I was wondering which one of these would be a better option. They're both 10€ and both seem to perform pretty well. I'd say the most important factor would be the noise, I looked at some reviews where arctic P12 outperformed the kaze flex and vice-versa. Does anyone have experience with these fans and if so which one should I get. Other reccomendations are also welcome.
Currently I have corsair ml120 in the front and a noctua nf-s12b redux in the back. The corsairs are about 2.5 years old and have been making a weird noise as of late.
Optimum Tech did a pretty good roundup of 120mm fans on his Youtube channel, and I think he liked the Arctic fans more than the Scythe.
Aerocool DS are the best fans you've never tried.
I say go for the Arctic. I have several of these fans and they have been great.
CPU: AMD Ryzen 9 - 3900x @ 4.4GHz with a Custom Loop | MBO: ASUS Crosshair VI Extreme | RAM: 4x4GB Apacer 2666MHz overclocked to 3933MHz with OCZ Reaper HPC Heatsinks | GPU: PowerColor Red Devil 6900XT | SSDs: Intel 660P 512GB SSD and Intel 660P 1TB SSD | HDD: 2x WD Black 6TB and Seagate Backup Plus 8TB External Drive | PSU: Corsair RM1000i | Case: Cooler Master C700P Black Edition | Build Log: here
  • 4 weeks later...
I've seen online that the P12s have a buzzing resonance at certain RPM ranges, which gets really loud, have you experienced/noticed that?
I'm looking at possibly getting them but not sure if I should because of that, since I really want quiet operation.
I am actually using these fans in my main system. I have 14 of the p12's and 1 f14. They are all running to a single fan controller and I keep them all running at a fixed 60% which is inaudible at around 1200-1300 rpm. They move a TON of air and have great static pressure. I haven't noticed any noise from them unless you turn them to 80% or higher duty cycle... Even at 100% they are not what I consider loud of obtrusive. Plus when you can get 5 of them for about 40 bucks it is a steal of a deal. I actually prefer them to the ML120s I use to run.
*edit* My teenager who is an RGB fan went with the Bitspower Touchaqua Notos RGB 120mm Case Fan - 5 Pack which were $50. They come with a rgb controller and fan hub with pretty good looking RGB, but the fans on them are definitely smaller than the p12s and they don't move anywhere close to the same amount of air or have the same static pressure, but they are also pretty darn quiet and decent fans on the cheap if RGB is your thing.
I see you are an individual of refined tastes - I am running 10 p12's and 1 F8 from Arctic in my case 🙂  I run them at full bore and the tone is pleasant and not intrusive
Workstation Laptop: Dell Precision 7540, Xeon E-2276M, 32gb DDR4, Quadro T2000 GPU, 4k display
Wifes Rig: ASRock B550m Riptide, Ryzen 5 5600X, Sapphire Nitro+ RX 6700 XT, 16gb (2x8) 3600mhz V-Color Skywalker RAM, ARESGAME AGS 850w PSU, 1tb WD Black SN750, 500gb Crucial m.2, DIYPC MA01-G case
My Rig: ASRock B450m Pro4, Ryzen 5 3600, ARESGAME River 5 CPU cooler, EVGA RTX 2060 KO, 16gb (2x8) 3600mhz TeamGroup T-Force RAM, ARESGAME AGV750w PSU, 1tb WD Black SN750 NVMe Win 10 boot drive, 3tb Hitachi 7200 RPM HDD, Fractal Design Focus G Mini custom painted.
NVIDIA GeForce RTX 2060 video card benchmark result - AMD Ryzen 5 3600,ASRock B450M Pro4 (3dmark.com)
Daughter 1 Rig: ASrock B450 Pro4, Ryzen 7 1700 @ 4.2ghz all core 1.4vCore, AMD R9 Fury X w/ Swiftech KOMODO waterblock, Custom Loop 2x240mm + 1x120mm radiators in push/pull 16gb (2x8) Patriot Viper CL14 2666mhz RAM, Corsair HX850 PSU, 250gb Samsun 960 EVO NVMe Win 10 boot drive, 500gb Samsung 840 EVO SSD, 512GB TeamGroup MP30 M.2 SATA III SSD, SuperTalent 512gb SATA III SSD, CoolerMaster HAF XM Case.
https://www.3dmark.com/3dm/37004594?
Daughter 2 Rig: ASUS B350-PRIME ATX, Ryzen 7 1700, Sapphire Nitro+ R9 Fury Tri-X, 16gb (2x8) 3200mhz V-Color Skywalker, ANTEC Earthwatts 750w PSU, MasterLiquid Lite 120 AIO cooler in Push/Pull config as rear exhaust, 250gb Samsung 850 Evo SSD, Patriot Burst 240gb SSD, Cougar MX330-X Case
Got tired of spending a fortune on ML120s when these p12s perform so close to them that it doesn't matter. at about 25 per fan the MLs would have set me back an extra $350 instead of $120 lol
