Correct Mount of AIO with Pump in the Radiator
57 minutes ago, Breeeee said:@StahlmannThank you for your reply.
But if I chose a front mount with tubes up, wouldn't I push the air bubbles into the CPU block, limiting performance? Same with bottom mount?
(I know, this wasn't part of the original question, only for completeness)
For best heat transfer you don't want air collecting in the block. For best flow and reduced pump noise you'll want to have the pump placed where air doesn't collects.
Air will go to the highest point in the loop
Bottom mount is a bad idea. Highest point would be the cpu block.
Top mount should be fine. But the pump is in rad might so air may gather there. Making it noisy. But you can add a couple washers to tilt the rad so the air rest to one end.
Front mount will also be fine. Tubes down is best. But if you can only do tubes up it fine.
What case is it?
