Hi all,
I've been going through my old electronics detritus lately, and happened to come across this:20201226_180801.thumb.jpg.58502432e20223c0d9cca122eca87ab5.jpg
The connector is a standard-looking 3.5mm, and the right end is a smooth, shiny plastic dome. On the other side of the dome is some 3M adhesive. And I have no idea what it is.
I tried it in both the microphone and headphone jacks on my computer with no results.
Any ideas?
https://linustechtips.com/topic/1285978-help-me-identify-something/
It's probably an IR receiver for a TV or some other piece of home theatre.
CPU: Intel i7 - 5820k @ 4.5GHz, Cooler: Corsair H80i, Motherboard: MSI X99S Gaming 7, RAM: Corsair Vengeance LPX 32GB DDR4 2666MHz CL16,
GPU: ASUS GTX 980 Strix, Case: Corsair 900D, PSU: Corsair AX860i 860W, Keyboard: Logitech G19, Mouse: Corsair M95, Storage: Intel 730 Series 480GB SSD, WD 1.5TB Black
Display: BenQ XL2730Z 2560x1440 144Hz
Just now, ve4grm said:
Interesting thought. I'm not sure what it would be for, but I'd believe it.
IR needs a direct line of communication, i.e. no closet doors inbetween your remote and the IR receiver.
This devices makes it so you can plug a cable into (for example) your setup box, run the cable to someplace which will never get obstructed and just stick it in place, so you can use the remote's IR even when said door is closed.
Usually I see them referred to a "IR extender"
To add, some video over cat/IP extenders also do IR, there is also IR over coax and I believe some TV tuner or capture cards might have had IR targets.
If you inherit stuff it might just be leftover from something long gone and just part of a spaghetti pile.
