VB audio cable: my audio input on any platform, goes into audio output
Solved by Kraken_05,
37 minutes ago, zdogg07 said:so basically for example discord, under "input device" is VB audio output and under "output device" is VB audio input. ive never seen a fix like this so someone please help
With your current setup, the discord output audio is your discord input audio as well like a loop. It is like holding a mic next to a speaker.
This is a good tutorial for virtual sound mixing and virtual cables I found:
